S42 Engine...
Richard
Try that search over on Bummerforums-
in the E36 section, there's a pretty good description
of how and what the S42 was.
the short version is that it's not a production engine,
it was a one- off for racing (touring cars)
to meet the 2L limit in the 90's.
Apparently rarer than an M12, from what I remember.
I read about it in an old BTCC book, and got excited... for about 15 minutes.
http://forums.bimmerforums.com/forum/showthread.php?t=162133&highlight=S42
hth
The S42 came in different versions, here is some data on the 8/1995 evolution.
Bore / Stroke: 86,5mm / 85mm
Displacement: 1998ccm
Compression ratio:12.4
Rod length: 145mm
Intake cam degree / spread: 312 / 94
Exhaust cam degree / spread: 304 / 98
Intake valve diameter: 35mm
Exhaust valve diameter: 35mm
Intake dimensions: 52mm wide / 29.7mm height / 14.85mm radius
Slide throttle diameter: 46mm
Carbon airbox
Exhaust manifold: 4-2
Engine management: ecu4a.1
Performance: (DIN 70020)
285hp at 8300rpm
245nm at 7000rpm
max rpm: 8500rpm
Petrol quality: Super plus ROZ 98
S42B20
S42B20 BMW Motorsport EngineA racing version of the M42 Engine, called the S42 is known. It was used in BMW's 320 4-door touring car, participating in the German racing series called STW (Super Tourenwagen Cup). It differed by having individual throttle bodies (ITB) for each cylinder and its capacity was enlarged to 1999 cc. It had eight fuel injectors instead of the standard four. Valve cover and airbox were entirely made of carbon fiber. Lubrication was provided by a dry sump system. Compression ratio was increased and a lightweight head was installed.
Horsepower evolution steps of the S42 Engine:
Year 1995 1996 1997
300 hp 308 hp 315 hp
In the last evolution step the engine puts out an amazing 158 hp/L. Compared to a modern racing engine it was a big achievement.
'64 R27 250cc #383851 18,000m
285hp at 8300rpm
245nm at 7000rpm
Year 1995 1996 1997
WOW!!!
John
1665778
guess we wont find any of these in our bone yards
and turn up the volume and ride along with screaming
S42 power at bike track ASSEN Holand
this is one F A S T E36 - listen to the ultra close ratio gearbox work
and slice through the field
and watch/listen how it is to drive off with a
light weight race clutch - proves it's not for street use
holy cats- is that active suspension in there? Those braces are...
fantastic.
Makes you realize what a bunch of pointless car porn
cross braces are if real race development does it that way...
