Alloy wheel refinishing
davidmcw
Just purchased a 1976 BMW 2002 with Cromodora "Daytona" 13"x5.5" magnesium alloy wheels. Would like to refinish. What's the best approach? Bead or sand blast? Wurth wheel paint and clearcoat or powder coating?
Previously: 1940 BMW 327, 1951 MGTD, 1965 MGB,1967 BMW 1602, 1969 Lotus Elan, 1970 BMW 2002,
1972 BMW 2002tii, 1973 Porsche 914, 1983 MB 240D, 1987 MB 300D, 1987 VW GTI, 1997 MB E320, 1992 & 1999 Miata
Currently: 1976 2002, 1993 MB 300TE, 2004 MB E320
I had my factory alloys blasted with aluminum oxide (I think) and then painted with a self etch primer and painted a current spec Mercedes wheel silver then topcoated with a very dull clear. I'm very happy with the results.
I'd find a reputable blasting shop who is capable on not destroying your wheels with too harsh an abrasive. Also check them for trueness and have any straightening done before they are refinished.
Good score, let us know what you end up doing and post some pics!
-=Ben
--> 1968 2002 <--
I just did a set of euroweaves for a car im bulding and I bead blasted them in my cabinet with black sand. then i used this duplicolor silver wheel coating. Im sure its just silver paint but it really worked great and looks awesome. Its got some fleck in it so it may not be period correct but i dont care about that crap. the clear that goes with it did not darken the silver at all like some clears do.
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Same great results last year as Blunt on 14" basket weaves with Duplicolor alloy wheel paint and clear.
____________________
Roger
'72 Malaga
RBenson685@aol.com
after cleaning/blasting etc use a self etching primer (I used Spees-Heckler in a spray can), followed by Krylon "dull aluminum" and then a Krylon clear coat. Lasts 5-7 years if you don't drive on salted roads...
..... " 'find a reputable blasting shop
before they are refinished"
that is the most important point !
find a wheel balancer - mount the bare rims on the spindle,
and just hand spin. If any wobbles are seen - stop there.
You could also mount a bare rim on the front of your car up
in the air and hand spin there to check for run-out.
'64 R27 250cc #383851 18,000m
"My understanding is that balancing
a magnesium - aluminum rim is near
impossible as they are very brittle"
wow!?!?! dat's a heck of a fishtail if there ever was one!
Balance: find machine/technician that can set the machine
for INSIDE spotting, and use Tape-A-Weight, inside plane only -
you don't deface the clean outside appearance.
I recently had my early factory alloys bead blasted, powdercoated (Bengal Silver color), and clear coated by an outfit in the East Bay. One glitch I ran into was I couldn't install the hub caps because of the added paint thickness surrounding the center bore. With a little elbow grease and a small sanding drum, I was able to fit the correct hub caps (Thanks BLUNT).
76 2002 Chamonix
06 530i Monaco Blue
18 i3 BEV Protonic Blue
87 528e Royalblau (Retired)
I've had good luck using ground glass for blasting alloys followed by Duplicolor's self-etching primer, silver wheel paint and then clear.
Bob,
Those Momo's look great. I have been looking for some background on those since you got them.
I have yet to find any. You???
They turned out very nice.
I recently had my early factory alloys bead blasted, powdercoated (Bengal Silver color), and clear coated by an outfit in the East Bay...
Powdercoating is a no-no for alloy wheels. No major wheel manufacturer does it or recommends it, in fact several recommend against it.
The heat of the oven (often not carefully controlled) can ruin the temper of the alloy. If it ever happens to you, it won't be with the car parked in the carport.
Cheers!
1976 BMW 2002
1990 BMW 325is (newest addition)
1990 Porsche 964 C4 Cabriolet
The heat of the oven (often not carefully controlled) can ruin the temper of the alloy causing the wheel to break. If it ever happens to you, it won't be with the car parked in the carport.
Cheers!
1976 BMW 2002
Thanks for all of the input. I'll strip the paint with Aircraft paint remover. I found a European Wheel Refinishing kit at ProperAutoCare.com that contains:
17 oz. Wurth Clean-Solve
10.2 oz. einzett Self-etching Primer
12 oz. Wurth Silver Wheel Paint
12 oz. Wurth High-Gloss Clear Lacquer
I'll let you know how they turn out.
