Tii Bad Grounds?
I have a couple of issues that I'm sure other 02 owners have come up against.
My signal indicator on the dash is intermittent. Up to a week ago the light would flash once and stop, but all turn signals are working and the "flasher" clicks loudly. For the last week the light has been flashing bright and consistently. TODAY IT'S BACK TO INTERMITTENT. Arggh! Is this a ground issue and if so where are the suspect connections? I know I'm not alone. :-)
My temperature gauge on the dash is jumpy. This too I believe is a ground but maybe a bad transmitter. If this is a ground issue where are the grounds?
I appreciate any input.
Thanks,
Paul
Paul Winterton
www.cybereyes.com
Cybereyes Images
Vancouver BC
604 689 3008
'73 Inca tii
Check out the flasher FAQ here: http://www.bmw2002faq.com/content/view/40/32/
And the pigtail ground for the jumpy temp gauge here: http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,324830/highlight,jumpy+temp/
Also, go ahead and clean all your fuses and fuse box connections and check your battery ground.
Good luck.
-Marc
'73 2002 (Agave) - Horst
i had exactly the same issue in my 72tii
i was the signal relay, the little black box
installed a new one and no mor issues
DON'T DROP THE BIG MONEY ON A NEW RELAY! Big Money gwb72tii is loaded, so if you want to go broke, listen to him. FIX IT per the flasher FAQ.
george,
i do believe you have the equivalent of an internet stalker chasing you around here.
mr/ms jhc, leave gwb alone, already. this is the wrong forum for these antics.
& 1 special alfa
you're lack of intelligent responses reveals your lack of knowledge about our cars
i tried every fix per the faq, grounds, connections etc
it was the relay
72 2002tii
1988 535is
