yes, BUT,....
two questions to be answered:
what type of pistons will be used? bathtubs, piano tops, or flattops
is it truely a tii head without the mechanical fuel pump boss, drilled and tapped?
if yes to question 2, then you'll need an electric fuel pump.
it's doable, but if it is indeed a true tii head, i'm sure you could trade it for a regular head to someone like me, perhaps....
what type is it: 121, or E12?
& 1 special alfa
The only difference in the head is the lack of holes for a mechanical fuel pump, 121, e12 both. (If you are hoping for hotter cam or bigger ports, they aren't there. Its the same head as a carb'd car) But as long as you have flat top pistons, either version will work with out interference.
(O=o00o=O)
So if you sre trying to hottie up the motor what would you recommend doing......somebody out there that builds hottie motor to slip into the old slot?
