FOUND a portable engine stand
jgerock
See down in the thread. I may still make a vertical support for it.
Other than using the standard-issue engine stand, does anyone here have any ideas for a small, short engine stand or cart that can be used to store an engine upright that allows work to be performed on it?
I've seen metal carts at Sears/Harbor Freight and other places for hauling tools around, but think they are too tall and you'd have to lay the engine on it's side.
Here is Bill Williams' cart which looks usable but might be a little top-heavy.
I'm thinking of something a little taller than this with larger casters
BTW - I did a search for "engine AND stand AND portable" which resulted in an old thread with this same question BY ME (LOL).
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,328310/highlight,engine+stand+portable/
Just a thought off the top of my head, it might be a relatively easy project to add large casters to a front sub frame that is homeless
The engine on the cart appears to be on a short stand and sitting on some 4x4s, looks really top heavy.
Maybe the bottom shelf has been well ballasted.
I've considered going this way. The ability to work on the engine at a comfortable level is really appealing. I've considered a scissor lift with the stand mounted to it.
One could raise the lift to work on the engine and then lower to move around overcoming the top heavy issue.
"Common sense isn't common"
I was thinking the same thing - maybe chop off the ends so it isn't as wide.
That looks pretty neat. Where did you find it? I get catalogs from C&H Distributors at work - they have some neat "back saving" lifting devices for warehouse use, but most are too big for my small garage.
http://www.chdist.com/material-handling-equipment/carts-trucks/d-87952-87952-153418
Very pricey!
http://www.chdist.com/material-handling-equipment/lift-tables-tilt-tables/d-90966-90966-153517
http://www.chdist.com/material-handling-equipment/lift-tables-tilt-tables/d-90938-90938-153517
For the ultimate
http://www.easy-run.net/c-9-professional-series.aspx
Much better
http://www.harborfreight.com/catalogsearch/result?q=lift+cart
What you are seeing in my photo is a engine stand, home made, sitting on top of a tool cart.
Casters on the upper stand would be good. Mike Pugh has the design, it is much like the one you posted.
1972 2000tii Touring #3422489
FAQ member #5
Thanks Bill - Mike Pugh just sent me an e-mail with some pics.
Here are the pictures Mike sent to me
Somewhere in my stuff I have a pic of what Schnitzer used - essentially a larger box frame (tube), had pins on the sides that specially made (extended motor mounts - bolted into the motor mount position), very simple. Will scan it on Monday if I can and post it then.
http://www.alpinabmw2002.com/
Called the Harbor Freight store in Dale City (VA) which is about 20 miles South. They had at least (3) of these in stock, so Susan and I braved the late Black Friday traffic and I picked up the scissor-lift cart.
$ 159.99 before tax.
Easy to assemble with just (2) end rollers, the pump handle and upright push bar (using 9/16" and 1/2" wrenches - not included in box).
If I remove the push bar, it could be used to lift a tranny, differential, etc. It will certainly help me work on the VW engine.
All the way down
All the way up (this puts the table right at my trunk opening on the tii
Called the Harbor Freight store in Dale City (VA) which is about 20 miles South. $ 159.99 before tax. If I remove the push bar, it could be used to lift a tranny, differential, etc. It will certainly help me work on the VW engine.
Jim, you have read my mind. That is exactly what I was thinking about. By mounting a stand like Bill's on top you could raise the motor to work on it and then lower it for transporting around the shop.
Todd
An engine mounted on a normal stand has always worked great for me - I do clutch work last, thus it's done either on the cherry picker, or I lower the engine on a careful arangement of a couple wood blocks and an old tire. We also use work carts to hold the engine and raise the car away from the engine.
1971 BMW 2002
38/38 DGAS
292 cam
TEP 4-1 header
Ansa Sport muffler
Bilstein Sports
H/R Sports
Full Urethane
IE adjustable sways
15x7 König Rewind
I am using a standard engine stand for the tii engine - clutch and flywheel removed first. I may build a small support stand w/casters using some scrap metal from work (welding by others).
For now, the scissor lift will be used for the VW. I always have trouble getting the VW engine off the jack and onto the ground so it clears the rear apron. This time, with my wife's assistance, I put the engine on my old skateboard then rolled it out.
The sideways mounting of the engine adaptor (as seen in Ben's picture) was sucessfully used by Marshall Lytle on his M10 engine - we looked up the mounting points on Keith Kreeger's website (www.my2002tii.com).
the skateboard will now be slippery!
Don
Don
