horn ID?
mthaynestii
there are numbers stamped on the horn - someplace
like 300Hz .....350Hz (for the frequency)
look at the washer at the mounting nut, or a seperate tag attached. . . etc
the lower the Hz number the lower the tone
try 'adjusting' it first, check the wiring with a test light
for current to each horn, try switching horns to the wiring to confirm that it's not the wiring...or the horn....
use a jumper wire from the battery to one side and a ground wire to theo other side
the high pitch horn is labeled "hoch".
Check grounds, the positive leads and as CD said, try adjusting before you give up on 'em.
