Replacing starter...Need help with a bolt..ideas?
jrhone
This bolt holding the bracket for the old starter wont budge...its too tight for a socket...or at least any 17mm sockets I have and I tried a wrench but I dont have enough room due to the oil filer and intake manifold...ideas? Its the LAST bolt I need so I can swap this...the hardest 3 bolts on the car...lol..
2018 BMW M550i X-Drive
1964 Volvo Amazon Wagon
http://www.project2002.com
Drench it in penetrating oil (PB Blaster, WD40 or some such). Try to get a closed end wrench on it and tap the wrench with a hammer - not too hard, repeated tapping may free it.
There's always Heat - a Torch lighter, MAP or Butane (use EXTREME caution).
Get a Flare nut wrench or crowsfoot to try and grip it.
Be persistent, there's always a way... you just haven't found it yet ! ;)
Cheers!
1976 BMW 2002
1990 Porsche 964 C4 Cabriolet
I just did my starter recently too, and I remember that bolt.
After getting all the other bolts off the starter (so it's dangling loose in there) I was able to get a screwdriver into the hole as sort of a lever, and unscrewed the whole thing - bracket, bolt & all. After a full turn to loosen, I was able to unscrew it by hand, remove the bracket, then the starter.
Not sure I'm explaining myself, but pretty sure that's what I did.
Matt
I needed a car, and a hobby....
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
The original colour was Malaga, paint code 021
Thx guys! got it! I used a 17mm wrench...and lots of PB Blaster....With enough strength it finally budged...
Might want to file this away for future reference:
Date: Fri Apr 02, 2010 8:32 pm
Subject: Since we (mostly) all live with rust on our 02s, here's an
interesting comparison of various penetrating oils:
Machinist's Workshop magazine actually tested penetrants for break
out torque on rusted nuts. Significant results! They arranged a subjective
test of all the popular penetrants with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
Penetrating oil Average load
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ..............214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone.
Note: The "home brew" was better than any commercial product in this
one particular test. A local machinist group mixed up a batch and all now
use it with equally good results. Note also that "Liquid Wrench" is about as
good as "Kroil" for about 20% of the price.
