M10 2.0 pistons&conrods
simon1989
What type you want? I have mild bath tub pistons and some connecting rods. I would separate the 2
-Nathan
My bathtub pistons I think are over sized and in OK shape. Take a look at them here. Also I believe that the normal 2002 has a CR of 8 or 8.3 so you should be fine. These on a 121 head pushed 8.5.
http://picasaweb.google.com/Tractorshop/ForSaleItems#
-Nathan
You need flat top pistons if you are going turbo. What head are you using. I believe the 1.8 head is larger combustion chamber than the E21 head. I have all of the measurments at the shop. The bore and con rods are the same between the 1.8 and the 2.0 on the late M10 engine, the difference is the stroke only.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
