where can i get a new wood board for my headliner?
andy.fulton
I did the same thing. I said fuck it and installed it like the front. Just glued the headliner over the lip where the back windshield rubber goes. Mine looks great with no ill effects. No leaks etc...
Charlie, here comes the deuce. And when you speak of me, speak well!
if you want to save your broken board, merely cut a patch sheet of thin stock aluminum, and use 5 minute epoxy to glue it over the crack. use some c-clamps or similar to hold secure until dry.
you might have to judiciously shape it to match the contour of the board, towards the ends. glue the aluminum such that it is on the side towards the roof. your patch will be stronger than the parent material.
i've used aluminum patch panels and epoxy to fix cracked heater boxes and under dash panels. nobody will ever know. it is a discrete repair.
& 1 special alfa
