vinyl sunroof, have not seen this before?
bongo007
very original and unmolested
Webasto (& similar) roofs were not factory fitted that I know of, maybe dealer fitted. They were not two-tone either out of the factory.
Car looks like it belongs to one of Esty's long lost relatives. hehe.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Looks like you have the same cocked driver headlight that I have, Esty.
Had to buy after the "hit & run", and I've fiddled and farted with the damn thing and just cannot get it to sit level.
I rarely drive at night, so no big thing, and inspection (Texas) doesn't care where it's pointed as long as it lights up!
Les
FAQ Member #17
It's just possible that you have two rights or two left headlight buckets. There are lefts and rights, and are extremely difficult to distinguish one from the other--I found this out the hard way!
If you drop me an e-mail, I will send you a column I did that describes how to tell one from the other. If you install a left bucket on the right side or vice-versa, the headlight will point all catty-wampus regardless of how you adjust it.
cheers
cheers
Mike,
That's more than likely. I tried to find a matching headlight to fit to my orig Euro unscathed bucket, only then did I learn that there are several varieties (bucket & reflector).
So I quickly put in some US buckets with Ebay lights. Actually the left (pass side) one is also cocked, so, grace goes with symmetry!
Les
FAQ Member #17
google or search the forum for webasto sunroof
I have seen webasto sunroofs before, what I havent seen is the entire roof, A pilar and C pilar covered in vinyl also.
sorry, my bad...i misunderstood...you can take your o2 to most good upholstery shops and tey'll put a vinyl roof on it for you...no o2's left the factory with a vinyl roof
