Nose question
PSloan
A long time ago I saw a template that outlined where to cut the nose skin to convert a late nose to early and vice versa. First, does it work? And secondarily - does anyone have the template?
I've got a boner for all aluminum grills. Wouldn't mind having a set on my 76.
Patrick Sloan
1975 inka 2002 - 2375719
1991 325iC
2001 325i
You just have to replace the area around the kidney. This is the only difference.
The BMW 2002 tii VIN 2719550 was manufactured on July 3rd, 1973 and delivered the same day to the BMW dealer Zeiss & Schwärzel in Mannheim. The original colour was Golf, paint code 070.
Hey Pat,
Think it was a common thing over in Germany when they ran out of "early" (or late?) nose panels a good few years back.
I honestly do not know if the tabs for mounting the grills to were in the same location (late v early) but you could cut the section out and include the two inner tabs each side, per the pics, and at least have then in the right place.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
actually, the tabs and supports for the side grilles are different, too.
You have to come up with some way to retain the early grille, and remove
the material that held the plastic grilles, as it gets in the way of the metal
ones.
BTDT.
