Where is this leak coming from?
smichaelq
A puddle keeps forming in the back passenger floor area.
The water is coming from the heel panel of the back seat; but there is no water in the under seat compartment when I lift it to check.
Is there some channel that runs from the trunk forward, under the rear seat area?
Strange...
1973 2002tii "Pinchy"
2006 Mini Cooper
1964 Vespa VBB
2007 Toyota 4Runner
http://qstii.blogspot.com
Strange...
Leaking back window?
+1 on the leaking rear window. You might also get some of that same leakage dripping into the trunk through the holes that are under the parcel shelf.
--John
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
....AND . . . . front window seal
pedal box, rear side window seals,
vapor barriers in doors, rusted hole in rear wheel wells. . . .
Sean -
I see there is a gap in your rear window lockstrip
I also recall your front windshield was missing the lockstrip.
Maybe try to use a garden hose to see where the leak is coming from.
Jim
I'll use the snow thats coming to test it out(?!?!)
No sunroof, so that aint it, but there is no puddling in the trunk. Im going to put some pans in there nad see if the melting snow collects anywheres.
When is the weather going to cooperate so I can get some dang work done?!?!?
2006 Mini Cooper
1964 Vespa VBB
2007 Toyota 4Runner
