Info needed on a hi/low beam & turn signal switch for a
bluedevils
switch. Didja check Realoem?
Only the wash/wipe switch was different on squarelights--later ones have the delay position on wiper speed.
I see what you mean, Al. I checked both bmwfans.info and RealOEM.com for my '75, which should be the same for your '74, and it shows three different P/Ns for the switch. someone more knowledgable than I will have to chime in.
Might try calling Carl Nelson, at LaJolla Independent, and see if he can help you out with the correct P/N. 858/488-1555. Jeff, at LaJolla Indep. may also know the answer. He drives a '75.
Bob Napier
I have a 74 tii. I need the part number of the correct switch on the column (left side) which controls hi/low beams and turn signals. TIA.
The parts book shows:
61 31 1 356 609 for USA 02 and tii model 74 and on.
61 31 1 357 000 for Euro models (not tii) 74 and on
61 31 1 352 949 for most Euro & all USA models up to 73
Probably the same as 357 000 below except it's not wired for left and right overnight parking lights as required in Europe
61 31 1 357 000 for Euro models (not tii) 74 and on. This one is marked for Italy and France,where lighting front and rear lights on the "outboard" side when parked on the street at night is required
61 31 1 352 949 for most Euro & all USA models up to 73. Goes on the right side of the steering column. Some US cars (72 & 73 for sure) are wired so the overnight parking lights work; not on earlier cars (my 69 doesn't have this feature). Believe it started with the 12 fuse cars.
We’re almost there Mike.
61 31 1 353 632 and 61 31 1 357 458 are the two listed for France & Italy. They are probably wired for the Countries needs - ie Reverse quickly for France (& maybe Italy?) and also to the horn for Italy. hehe.
61 31 1 357 000 is for Euro, and as you say, probably for the side/parking light feature. Not sure why it’s not noted for the 74 & up tii though.
61 31 8 648 007 I believe is the early one up to modell 71.
