Removing old roundels fron hubcaps
nbristow01
Before resorting to the torch you might try soaking them with WD-40 spray and letting them sit for 5 min. or so. It works very good at getting underhood decals off and might work on the hubcap Roundels. If not, you've lost nothing but a little time and a little WD-40.
Bob Napier
Goof Off which is acetone and xylene should dissolve the glue, faster than WD-40.
Andrew Wilson
My method:
set oven to 200f
put cap in oven for about 5 minutes (makes a little stank)
wear two oven mits--remove cap, use small pocket knife to pry up a corner and then a wooden Popsicle stick to pry around the remainder---the glue will turn dark yellow/black and fully come off with a soak in goofoff.
Do this only when your wife/girlfriend/husband/domestic partner is out for a few hours.
-Ben
--> 1968 2002 <--
My method:
set oven to 200f
-Ben
I always wait until she is asleep so she has no clue
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
I just did this last week. Goof Off is the way to go. You may kill a few brain cells, but it works like a champ. Used a cheapo Harbor Freight yellow trim pry tool after goof off did its job - no scratching of the cap. Also used it to remove the glue residue left on the cap after roundel came off.
1970 Agave work in progress
Born on May 14 1970 and delivered May 19th 1970 to NYC to Hoffman Motor Corp. Agave code 071
new guy
help appreciated!
other cars: 1991 318is / 1999 540iT
If I can find a decent mechanism, I'm going to turn my set of four into some wall clocks. I looked at Hobby Lobby for the mechanisms...but were a bit too small...and way too cheesy for my taste. I'll make one for me and gift the other three to interested parties if I find the right "look".
Samplemaven
BMWCCA #420368
'72 2002 Tii Inka restoration project
'07 550i Titanium Silver, steptronic...ED 2006
i made several clocks from hubcaps & wheel covers a few years ago...i got the works at michael's a crafts store like hobby lobby
