Fan Blade Size
depends on your climate?,
if air conditioning is installed?
all the emission controls?
all add under hood heat -
the larger "tropic' fan will also make more NOISE
either is 'correct' depending on your needs
Mine was not cooling as well as I'd liked, so I took out the shroud and put in a tropic fan blade. So far, it is cooling better, but it has not been tested in extreme heat yet. My '02 still has its orig. radiator.
'75 Sahara 2002 Dieter (sold)
'14 Blazing Red Metallic Mini Cooper
'73 Sahara 2002 Franz
