Fuel Pump Gaskets?
I'm prepping an engine and there is a gasket between the head and the insulator block for the fuel pump. I can't seem to locate a part number for this gasket although it can be seen on this diagram below, are there supposed to be two gaskets, one for each side of the insulator? Any idea the part number? Thank you people. -Ben
--> 1968 2002 <--
order the insulator - the gaskets are bonded to it already
really important is the plastic inserts (#3) in the mounting holes
of the pump sliding over the studs, then 2 flat washers, and finally
2 Nyloc nuts - without the plactic insulators (#3),
washers and Nyloc nuts =
the pump comes loose very quickly
