Nostalgic Air Parts---anyone install this system?
BDB
Gents,
I"m interested in installing a universal system from Nostalgic Air. I'm considering ordering the following:
Universal AC System:
http://www.nostalgicairparts.com/air-conditioning/universal-ac-system-select-an-evaporator-451.php
Evaportator (though this might be too wide)
http://www.nostalgicairparts.com/air-conditioning/ud-105-under-dash-air-only-evaporator-unit-312.php
Also one of Hobiedave's brackets if he still makes them.
I am not sure which Sanden compressor comes with the kit but I'll ask tomorrow.
Has anyone installed this company's AC system? If so, do you like the results? And was install a bear or doable? Any particular things you remember being a pain during the install?
Looks like I have their UD-120 Unit.
http://www.nostalgicairparts.com/air-conditioning/ud-120-under-dash-evaporator-unit-chrome-face-87.php
I inherited this with the car, but, as you can see, the width dictates you modify the glovebox which I also did not do, but it's quite a neat job; just needs straightening & the loose screws tightening.
It also worked pretty well until it ran out of freon. I'll re-charge it one day.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Les
Wow, thats a wide load!
Is it the R-12 version you have (freon)? I am always suspect of how an aftermarket R-134 AC works as compared to a factory R-134 one does
Bob
To be honest, not real sure. I'm told it's the original/old type.
Even in high heat TX I never really bothered running it. My Wife said it worked real good (cool) though.
Les
FAQ Member #17
I've been following a discussion on the bf.c E24 board re A/C, freon and R134. From what I could glean the consensus there is that a parallel flow condenser will allow R134 to perform as well as R12.
Cheers,
Ray (the A/C on the E24 broke right after recharge, the Thursday before the Vintage)
Les
Bob
Ray
Did you have to open the windows Ray?
It's June, are you still in China?
I just got an extension (order!) to stay in India until end of Sept. Home in July for 2 weeks though.
Cheers,
Les
Bob
Les
FAQ Member #17
If you followed the other thread, we were blessed that the central locking unit gave up, however the power windows did still function.
I do have a habit of actuating the rear windows at the same time, which usually throws the breaker. :)
I am unshackled at the end of this month (but my U.S. contract says I begin there on May 1, 2011. No they are not paying me yet!)
Cheers,
Ray (yes I should be asleep!)
Cheers,
Les
Bob
Ray
Ray,
Thanks for the info on the parallel condenser. I'll make sure that is the type I get if it really makes it as cold as an R12. I've sat in a R12 charged MBZ and man, you could freeze meat in there if left on high for 5 minutes.
Happy to contribute, Mr. Toast!
Talk to these guys, find the biggest parallel something that'll fit. They'll work with you.
http://www.supremecondensers.com/index.php
Cheers,
Ray
Ray,
Ray
