info on install of stainless brake hoses
Thanks all,
Very confidence inspiring replies.
Will do..
Hose connection saturation with penetrating oil prior to removal
Use flare nut wrenches
Plastic wrap under m/c cap
Bleed the system afterwards
Denatured alcohol for clean-up
Is Dot 4 still the way to go on brake fluid?
I may be the odd man out here but I wouldnt use teflon tape on braided brake lines
Blunt's right, I wouldn't use teflon tape on those metric bubble flare lines, they aren't tapered NPT connections and don't seal with the threads, they seal at the flare. tape won't do any good.
But he's still the odd man!
Ray
Ray
Don't forget a 7mm for the bleeder screws.
they are not all 7mm.....depending on source they could be 6,7,8 or 9mm. i recently worked on a car that had a different size at each wheel.....
Are these flares as well?
1995 Toyota Landcruiser
1975 2002A
1989 Dodge Raider (sold)
1974 Toyota Landcruiser (very sadly sold)
1994 BMW 530i (sold)
1992 BMW 325i (sold)
1970 2002 auto sunroof (sold)
Not Flare Nut wrenches. A box end wrench will work. You slip the wrench onto the bleeder, then put the hose onto the nipple. Pay attention to which way you will be turning the wrench to open the bleeder (righty-tighty/lefty loosey) as the movement of the wrench will be limited.
I found that the Craftsman Professional series combo wrenches have a smaller profile on the box end. I have the regular Craftsman wrenches in my toolbox, but keep one of Pro ones in 7mm just for doing brakes.
Steve J
& too many bikes
