Help...
Blue2002
reapply, let it sit and double nut it. Can I say that here?
I assume your talking of the exhaust studs.
Don
Don
They should be studs...not bolts. If you just want to remove the nuts and allow removal of the downpipe, I recommend heat...at *least* MAP gas if you don't have access to hotter gas torches. Get 'em hot, then use a long extension and 6 point sockets (NOT 12 point!) Don't mess with removing the studs unless you have to...and then, I'd recommend taking the entire manifold off the car. Not always fun.
Some nuts are 14mm, some 15mm, and some 16 or 17mm....depending on what previous installer used. The current ones sold by BMW for this application are Copper clad (this is a GOOD thing!) and 14mm I think...making subsequent removal much easier.
HTH!
Paul Wegweiser
Paul Wegweiser
I think mine are 15mm (socket size). One broke so I replaced it with a bolt.
Use a long 1/2" extension and big ratchet or breaker bar from underneath after penetrant/heat application.
