SOLD 1971 2002 - Price advice needed SOLD
2double02
All,
I am seeking advice on the value of my 71 2002. I am selling it to fund the restoration of another one. I realize it will be difficult to recover my investment in the car but I built it with no intentions of ever selling it. I can't find too many similar cars to compare it to so I am asking the experts. Feel free to respond via the forum or directly to 2double02@gmail.com.
Thanks in advance for your help.
Pics:
https://picasaweb.google.com/2double02/1971BMW2002
General
The car looks as good in person as it does in the photos and was recently named People's Choice of 85 2002s at Vintage in Winston Salem, NC. All work described below completed was within the last 18 months with lots of help from BMW 2002 faq members and talented local resources.
Body
Originally finished in Sahara beige. Any identified rust properly
repaired with new or rust free donor panels. Spare tire well replaced
with an e30 well. Terrific original rear shock towers. Car was epoxy
primed, blocked several times, and sprayed with Dupont base coat/clear
coat in Verona red. Buffed and polished to a gorgeous liquid like
finish. Front and rear side markers deleted. Engine compartment
finished in satin back. Floor pans, inside and out, undercoated along
with trunk. New euro front signals, belt line and knee trim, badges,
2002 emblem, trapezoid mirror, trim between taillights, license plate
lamps, front windshield, front and rear window rubber and lock strips,
door rubber, outer door chrome and felt sweepers, door sills, antenna,
rain gutters and proper aluminum wiper blades. Rear bumper
professionally re-chromed with euro seam covers and new rubber trim.
Any remaining trim cleaned/polished such as rockers, b-pillar and
lower rear quarter window pieces. Kamei style front spoiler
seamlessly molded to car with small tubular reinforcements from lip
back to original rust free front valance. Hella H4 headlights. The
exterior finish is nothing less than outstanding. The paint quality is exceptional.
Interior
Custom vinyl stitched dash by Chris Willet complimented by new leather
Momo steering wheel with white stitching. Vinyl covered console face
with DIN type Sony AM/FM/CD powering two 6x9" Boston Acoustic speakers
mounted under the rear seats. New OE headliner, sun visors, shift
boot, shift knob, rear parcel shelf and golden wheat colored loop
carpet by World Upholstery with padding. New retracting seat belts in
front. No rear belts installed but will include originals if
requested. Door panels and rear panels are from a later car and are
in very good condition. The front panels have been installed on new
boards from Aardvarc racing. Front seats are adjustable Flofits
mounted on refinished e21 Recaro rails. Front and rear seats were
reupholstered in matching vinyl a few years ago and still look
terrific. Recovered rigid gray trunk panels with custom red trimmed
black carpet mat by esty.
Suspension, Wheels and Tires
New Bilstein HD front struts, strut mounts, strut caps and ball
joints. New H&R Sport springs lowering the stance by about 1.5". New
Bayern Mesh 15x7" wheels with polished lips wrapped in new Falken Ziex
912 tires. New inner and outer axle boots.
Hydraulics
New front brake calipers, pads and rotors. New rear wheels cylinders
and shoes. New brake master cylinder, clutch master cylinder and
clutch slave cylinder. New emergency brake cables. New brake fluid
reservoir and proper fabric lines.
Under the Hood
Dry motor that does not smoke or burn oil mated to a smooth shifting
4-speed transmission. New water pump, NOS peanut intake, Weber 38
DGES carburetor, air cleaner, MSD high output coil, electronic
ignition, Bavauto high performance plug wires, Bosch platinum plugs,
distributor cap and rotor, belts, hoses, fuses, fuse box cover,
battery and battery cables. Re-manufactured high output alternator
with built in regulator and Bosch starter both still under warranty.
Radiator fully serviced. 4 into 1 header feeding a new Ansa
resonator and Ansa Sport center exit muffler all with new mounting
hardware. Recent oil change with Amsoil high zinc 20W50 full
synthetic.
1960 Austin Healey Sprite | 1974 Ford Bronco | 1974 Porsche 911 | 1989 Mustang GT | 1995 Porsche 911 | 2017 Porsche 911 | Always in Search of a BMW 2002
So wat number do you have In mind..(quote="bsulecki"]All,
Pics:
General
Body
Interior
Hydraulics
Under the Hood
synthetic.
So wat number do you have In mind.i was looking for a 2002 got a budget.(quote="bsulecki"]All,
Pics:
General
Body
Interior
Hydraulics
Under the Hood
synthetic.
Pics:
General
Body
Interior
Hydraulics
Under the Hood
synthetic.
Best advice I can offer. Post it on Ebay and let the market decide.
As a tastefully done non-Tii I'd put in the mid-teens.
Andrew Wilson
I saw your car at The Vintage, and I thought it was done to a high standard. I am sorry you have to sell it, since it would be hard to recover everything you put into the build. My recollection is that it had only been driven a few hundred miles since the full restoration was complete. Your paint was perfect, your wheels were drawing admire/envy, and I loved your front seats. GLWS.
-Marc
'73 2002 (Agave) - Horst
Thanks to all for the advice and compliments. The trip to Vintage was one of the first drives since it was put back together. It probably has less than 300 miles in total since completion. I enjoyed the restoration process so much that I would like to do another one to a lower standard that I will be more prone to drive everyday. Friends and family are convinced I will not be able to part with it and they may be right. Definitely a labor of love.
Instead of selling and restoring one to 'lesser' standard. Enjoy and drive this one. No one else will treat it like you do.
Andrew Wilson
Wow nice car, as the forum suggests hard to peg a price on such a beauty.
All I can relate is what I have experienced in my recent try to sell a very nice # 2 condition 1972 Golf Yellow in So Cal.
Received a 17K offer but refused due to wanting all my org. literature & 70's ads and having roughly 25k in it. Probably dumb on my part but I don't have immediate need to sell.
Your overall condition is nicer albeit custom, I do really like it.
I would suggest 20K
Mine is pretty std.
Doubt if this helps you.
I personally think ebay is a low ballers world .
Golf Yellow 1972 Roundie, Std, no mods ,no rust, no track days & restoration 95 % there
Jim,
Thanks for posting the great pics. I think yours are better than mine. I regret not spending more time talking with folks at Vintage but we had our 2-year old there and we sepnt a lot of time running around with her.
Brad
