WHAT THE F@%$#@ ... HOW DOES THIS HAPPEN?
Meintii
Thanks Rey, my heart skipped a beat to think about taking both cars apart to change them. I am trying visualize how that boot thing would fit up through the control arm.
The three bolts that failed on Zac's (speedwell's) car, for whatever reason, are three of the most important bolts on the car. Get those right and check them often. Stock bolts, safety wired and locktite.
I still cringe to think about this happening at speed.
1972 2000tii Touring #3422489
FAQ member #5
  • Replies 43
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
The company I work for uses a lot of fasteners. I would agree that Stainless is not the way to go in this application. I also would say to be a little cautious with fasteners. The company we use has changed suppliers on us several times and really made a mess for us. What should be the same parts became offshore nightmares that did not meet the same criteria for our needs.
1975 BMW 2002 Fjord
I looked at mine (I am putting them together as we speak!) and it will fit through the hole in the lower control arm, but the manual shows it on top. Also, the bolts are plenty long enough to install it that way.
Great to have so many EXPERIENCED and KNOWLEDGEABLE people here on the FAQ!
Thank you,
rey
I'm a BMW Zombie and there's no cure!
having changed out factory ball joints, it is apparent, from the factory, the riveted joint is under the arm and for both safety and geometry that's where I put them when replacing. A parts diagram is not an assembly manual. Concour with what has been said about not using stainless for load bearing applications. Also the upper mount didn't work so good either.
RK in OC
ex- 67 1600ti/Aplina
http://rogerspeed.tripod.com/bmw_1600tialpina/
83 A/R Spider Veloce
"I come from a broken home, I should know, I broke it" Bazooka Joe
Roger, are you saying the ball joint sits on top of the control arm or mounts up through it?
"... It also appears your lower balljoint is mounted on top rather than under the control arm..."
under, up and through
RK in OC
Zac,
The car is fixable...The important thing is that your ok! If you need any spares, let me know if I can help get her back on the road.
Best,
Russ
1970 Grey 02 (the never ending project)
2007 328xi coupe (DD)
and a couple hondas for the kid.
The reason the bottom safety wire bolts cost $7.40 ex if because they are hardned. Very much hardened .... more than stainless steel could ever be. Use the correct OEM bolts and don't worry about rusting. If they get corroded, replace them in 100 years.
......oh yeah, you can use stainless safety wire .... it won't rust and is about as hard as the standard safety wire. Stainless WIRE, OEM bolts .....
OK!?
Thanks for all the kind words! Im sure youll see my wanted ads in the wanted section from my poor ass to replace all this stuff again for the second time in 4 months.
So can I gather that the ball joint is okay installed on top of the control arm as it is? And obviously I will use OEM bolts when I put it back together.
Should I try to go after fastenal to give me some $$ for their bolts failing?
Zac Cardinal
1972 2002tii's Blog
1976 2002 "Margie"s blog
Metric Grade 10.9:
Sigma(y.s.) = 940Mpa
Stainless 18-8:
Sigma(y.s.) = 551MPa
Ref: http://www.boltdepot.com/fastener-information/Materials-and-Grades/Bolt-Grade-Chart.aspx
Stainless is much more ductile than hardened steel fasteners. I'd bet the bolts stretched, leading to failure after joint separation.
That's a bummer, man. That car looked awesome... I'm sure you'll get it back in shape in no time
i know i am, i'm sure i am...
Wow , that is nasty, "luckily" theses catastrophic failures happen at low speeds when there is max torque on the suspension, turning at slow speeds is the bad time, into a driveway at slow speeds=max torque load on suspension. Morris Minor "trunions", (spindle uprights) are a 5/8 thread , they shear like a carrot ,always when turning slowly or parking!! .I concur on the stainless steel bolts bad for loads & they stretch & shear very easily.
Good luck with the fix, a wake up call for us all, check them bolts !
1970 4 speed 2002 (Daily driver/track car )
1974  Hybrid powered twin cam engine, Pig Cheeks , ( now a round tail.) Getting ready to Sell
