tii throttle return spring
p1010002.jpg?bcPQ8g8A6Zi19_f6
the spring on my wife's 73 tii has once again flung itself to the pavement. I tried the local 02 specialist (nate smith) but was told the part is NLA. (spring is located under the intake manifold and is quite long)
I've got a few misc springs from hardware store to do a temp fabrication. but I'm looking for a long term fix. the last short term spring lasted a few months.
there has got to be some part that will fix this for good, or a used one at least. my wife has difficulty returning the GO-pedal w/ her toe!
thanks
Hi,
the GO pedal actually has 4 return springs
on it. so if the pedal is not going back by itself
then the pedal box is probably binding on the pedal
shaft or the block linkage point may be the culprit.
check both. as for the spring, use a plastic zip
tie on the engine side so you don't loose any more
and just find a spring that is relativly slack in
it's strenght.
good luck
stone
