Updated 2/10: huge assortment of parts, some e30 too.
IE Solid rear subframe mounts, brand new. $100
Ronal Tii alloy wheel, 13". Tire is excellent, looks like it's never been driven on(185/70R13) and has no cracking whatsoever. $90.
Automatic flexplate & torque converter. The flex plate ring gear is excellent, torque converter is pretty much a freebie with the flexplate. $25
$5 for this one.
$10 for the center kidney, roundie.
Set of black shallow grills, all slats are intact with a few missing slat covers. $60
Set of shallow grills with one mounting tab missing, all slats there, but a little bent. They are not bent much, replace your grills missing slats! $60
One more solo grill, passenger side. $30
M20 Valve cover $35
S50 throttle body $40
SOLD: E30 325i TB $35
36-1 ring. $20/ea
Set of coilpack spark plug wires. $10
SOLD: Cleaned up water bypass pipe, unpainted. $20
E21 320i water neck to clear the late E21/E30 M10 intake. $15
VDO water temp gauge 100-250 w/sender. I bought this for my turb02 thinking I had an oil temp gauge, but I actually had a water temp gauge so no need for it. Never used. $30
Driver's side roundie taillight lens, has nicer chrome ring than the passenger side(pass side sold) $30.
Automatic pedal box. It's in excellent shape and has no rust on it(besides obvious surface rust on brake pedal). I have the brake pedal pad and pedal box pad to go with it. Still has the complete exterior pad piece too. $60
Round washer fluid bottle with cap. $25
5-blade engine fan, I have a few of these $5
'76 steering wheel horn pad, one tiny cut but I couldn't get it to show up when taking pictures. $10
Automatic selector lever/unit. Some pitting on the lever. $10
Automatic console surround. pretty clean, small damaged spot on the back side(towards the e-brake handle). $15
Driver's side rear big bumper "accordion" in great shape. $10
Blue headrest, no tears/cuts. $10
Console stereo faceplate, fits below ash tray/hazard switch panel. Black powder coated aluminum, fits standard 1-DIN receivers $15
320i 2-sensor water neck, $15
Passenger side arm rests, 1 saddle, 2 tobbacco. $10/ea
Rear autoflug seatbelt receivers. $10/pr
Camshaft cover. $5
Taillight buckets, 3 passenger side, 1 drivers side. 2 good pass side $20/ea, drivers and passenger side ones that need cleaning. $10/ea.
Cibie H4 headlight in bucket w/o bulb. $35
IE exhaust header collector adapter, used for a week, comes with the band clamp. I've now got a completely different exhaust planned out. $60
Driver's side armrests. $5/ea
Stuff surrounded by
Blue box = $5
-hub
-pair of hood hinges
-ebrake boot covers, one has a very small tear on top
-bare door handles (ea) 2 passenger, 1 driver
-rear quarter window latch
-ash tray with chromoplastic flaking(could probably glue back down)
-black rear ash tray
Brown = $7
-passenger door handle with insert and bolt
-steering column top pad (ea)
-steering column under pad(circled in yellow accidentally)
-differential hanger w/stock bushings
Yellow = $10
-bolt in battery tray with lower leg cut off
-pair of window cranks
-glovebox dash pad crack free
-seat slider release mechanism, ea
-under dash pad(actually $10, should be circled in brown)
Red = $15
-Plastic under steering column cover
-metal under steering column cover
-Square washer fluid bottle with pump/cap(don't know condition of pump)
-Gloveboxs with crack free pads
Purple & Green = $20
-Round washer fluid bottle with white cap
-metal under steering column cover, the better condition one of the two
-bolt in battery tray, has rust but no rust through holes.
Grey = $40
SOLD: Recaro seat adapters(pair for one seat)
I also have a bunch of e30 stuff if you're looking for something, most of it is listed here. http://www.nwbmwforums.com/viewtopic.php?t=13086
I will take the 318 intake on the right. or which ever one is in the best shape? I can get it bead blasted to look good. also one of the bypass hoses for the manifold. do you have a passenger side armrest? if so I'll take one don't matter the color.
Dave
dave.hobiedave at gmail.com
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
Well...had a minor problem with my car today...spun a rod bearing so I won't be able to get anything shipped out until saturday. Sorry for the delay, hopefully one of my spare motors is good...
bump. Soon I will add an H4 headlamp relay wiring harness, E21 water neck, passenger side arm rests, roundie taillight buckets, cibie H4 headlight w/bucket(no bulb), and some other stuff which I can't think of off the top of my head.
