Ideas on steering?
the 74 sedan steers easy 185 60/13s 36 psi small steering wheel
The touring is a truck 165 80/13 36 psi stock bus wheel.
WHY? I am old but upper body strenght is still good easy bench 225lbs????
Old wider tires and small fat wheel should require more effort or did I just flunk Physics?
3421912 ask john
Red Baron a 74 sedanw/ dual webers ,spring,steins,bars. body shop for a full make over
Red Baroness a 71 1600 touring new to me and on the street in Limburg
Old Reliable a 93 318 m42's are soooo cool
Do you have strange offset on your wheels?
You didn't mention the age and condition of your front end components. Dry pivot points is not a good thing on any mechanical device.
Ahlem
'76 2002
'90 M3
'90 535i 5 speed
'89 325is '91 318is
'87 325is
phyisicz must be reversed in Holland from USA ?
and your 'other car' would be even lighter steering with 185/70 x 13" tyres
for the Touring look at the quality of oil inside the
steering gear box - might have GREASE from P-Owner?
stiff idler arm bearings (plastic) ?
stiff tie rod ends?
center steering link rubbing against the trans?(bent up)
bearing condition in upper strut mounts? - you can just drizzle
oil down from the top into the ball bearings
wrong washer positioning under the top strut bearing mounts
causing friction with the strut insert?
'64 R27 250cc #383851 18,000m
Actually I do not Know car was restored several years ago. Passed the very tuff Dutch Inspection process this year. Wheels are stock steel on the touring and Alpina s on the sedan? Very new tight on the touring older on the sedan but no slack or drift at speed.
Touring is /has not been driven much since restoration.
3421912 ask john
Will give it a look see The touring is too tuff to turn at a dead stop . more like a 50's pick up with a flat tire.
thanks cd
3421912 ask john
well, there's your problem. Your steering muscles aren't your bench press
muscles...
heh.
Serously, I have a series of excercises I do before trying to race on slicks...
it's a lot of shoulder work with high repps and relatively low weight.
Like others, I'd start comparing the cars- and I'd jack up the hard- steering
car and see if it is binding all on its own.
A dry steering box can bind like crazy....
hth
