Any easy to find wider 13" steel wheels?
Nicad
I have heard of others here running them just fine on an original early Tii 5x13 steel rim which uses the stock hubcaps.
That rim in th epic above is the exact rim my friend runs on his 02. 5.5x13 with 205's. There are no provisions on that rim to hold a hubcap but he does run beauty rings and it is a great look
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
185/70 13 tires need a minimum of a 5" wide rim.
The steel wheels from the later square tailed cars are 5x13 with an ET (offset) of 29 mm. Those fit perfectly on the 02 with 185/70 13 tires.
The tii alloys are 5x13 with ET 26 and also fit perfectly with 185 tires.
The steel wheels from the E21 (320i) look almost identical to the later style 2002 steel wheels, but are 5.5x13 with an ET18 which will fit the 2002, but aren't the ideal offset.
John
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
