I promise I searched...new owner help
turbotom09
Well I've owned my '02 for a couple months now (I will make an introduction thread when I'm not at work; photobucket is blocked here) and I have a slight leak in my windshield seal when it rains hard. I put clear silicone on it to fix it temporarily, but i finally ordered in the new seal.
My only question: is the lockstrip a universal part? Will a windshield shop be able to cut one, or do i need to order the strip? (If so where from?)
Also, any Dayton, Oh shops you guys would recommend?
Thanks a ton, I've already found gobs of helpful information on here!
75 Inka 2002-"Holly"
92 240sx KA-T
94 Infiniti G20T-"Eloise"
04 ZX6RR-"Mia"
Hi we can get you that strip for sure you better not try some sort of universal one. Give me a call and I will fix you up with one they are not expensive.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
the only other car that uses the same profile
locking trim strip is a SAAB 99 from the 1960's - 70's
as you can see in the illustration, the sides need to lock into the rubber
seal with the proper shape. It's important to expand the rubber
so the glass stays on the car when you colide with something
and your body trys to exit the cabin. Also expanding the rubber
to seal against water leaks. Order the correct strip today
Order from BLUNT. he includes free ice cream with every order.
;-)Ray
THAT'S what that white goo was in my parcel!!!!!
Now for the useful information: The lower corners can be a PITA to get set in. Look through the archives to see the methods that people here use. Some go for the installing the glass/seal/lockstrip all at once, others go for the glass/seal install, then put in the lock strip. Foamy glass cleaner is the preferred install lubricant. Spend the extra dollars and get a REAL BMW seal. The second sourced ones have a hit or miss reputation.
Search to find out about the locking teeth or 'gator strips' that were used on the early cars . these need to be removed (drill out a few small brass rivets)before installing a new windsheild. May have already been done, or may have never been on your car. I know they were on the early cars, not sure about the later ones.
Steve J
& too many bikes
Steve,
Would you recommend I try the install myself? I can turn a wrench, but I've never attempted anything to do with windows(other than easy stuff like regulators)
I'll make sure i get some aerosol window cleaner.
And I ordered an aftermarket seal, but not a URO as I've heard of bad experiences with those.
92 240sx KA-T
04 ZX6RR-"Mia"
If you have not done this before and you do not have any help that has done this before, go to a shop. 15 minutes and short money and it is done and leak free.
Find a shop with an old dude in it. He will whip it out in a lickity split
1972 2000tii Touring #3422489
FAQ member #5
There are pros and cons.
Like Bill said, if you have help, it is do-able. I've had some glass go in easy, and some was a beyotch. My less skilled neigbor cracked the corner on one windsheild by pressing a bit too hard. (He was used to replacing airliner glass) If you do it yourself, you get satisfaction, cost savings, and set your own schedule to do the work. You will also stand the risk of breaking things, working like hell and still not getting it to seat, and burning up the better part of a Saturday.
If you have a shop do it, you will: pay money, have to wonder if they really know their stuff, worry that they won't treat your car with the care that you do. Of course, if they break it, they pay for it. If it leaks, they fix it.
You could almost make this into a flowchart to come to a decision.
Another tip, leave the new seal and lockstrip set out in the sun- it helps make them more pliable for the install.
Steve J
& too many bikes
I've never installed a windshield before, but I vaguely recall reading that the trickiest part is installing the lockstrip after window is mounted. If that's the case, it may not be too bad. I replaced the lockstrip on my rear window this summer, and was surprised to find it was a much easier job than I thought it would be. You need the right tool and I think it helped that I installed it when it was warm.
Of course if you can find a professional who can do the job at a reasonable prince, that might be the easiest option.
Good luck!
Self or Shop: I just did mine 3 times in 1 week, to get it set properly, and it's still not 100%. This isn't the first time I've done one. I'll have a shop do it next time. Your biggest challenge will be getting the seal to lay flat on the metal, all the way around.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,278563/highlight,/
Looking for a Dayton, OH shop? I think we can all recommend Mike Self (Mr. '02 himself). I'm pretty sure he's close to Dayton. You can find him thru the FAQ.
mac.
Mike and Jim Denker both use Mike Macarthy (sp?) Not sure the name of his shop, but I am sure they will notice this thread soon.
Great to see a new owner pop up!!! But dang, you just missed our annual gtg and drive!! Can't wait to meet up!
-Jason
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,363501/highlight,/
(O=o00o=O)
in and around Dayton (I'm in Beavercreek), and a larger active group in SW Ohio. Drop me an e-mail off-line and I'll put you in touch with Jason (Eurotrash on the board) and Jim (Sahara 75) who keep the roster and perpetrate many of the events.
If you're looking for a good mechanical shop in the area, try Foreign Auto Service in Huber Heights. Mike McCarthy owns several 2002s and has been working on 'em since the 70s. Bodywork: C&H in Fairborn. Ed has done at least a dozen 2002, including both of mine.
As for your windshield leak--most any good glass shop should be able to squirt some sealer in between the gasket, glass and body to stop the leak. If your gasket is old/brittle/cracked, get a new factory gasket, not an aftermarket one. Only the factory gasket fits correctly.
cheers from just down the road
Thanks guys! I was actually down at foreign auto service a couple weeks ago, and met Mike. He gave me an extra fender he had laying around (very nice guy). I should be getting my new seal within the next few days, I don't think I will try to tackle it myself, I don't want a cracked windshield!
92 240sx KA-T
04 ZX6RR-"Mia"
