rear quarter panel skin
MicahDolen
What year?
should not matter, unless you do or do not want the glued-on stiffener plate that harbors rust, otherwise they're all interchangeable regardless of year.
& 1 special alfa
If he has cut quarter panel from the back of the door to the rear end it does, in fact, matter. I am looking for pre 74.
other than the aforementioned glued-on stiffener sheet, the panels in fact, are identical.
i'm not including the extra reinforcements at the bumpers, found on squaretails, but the skins are interchangeable. there may be some minor patching to do at the rear corners depending on the quality of the 'de-skin', but they are interchangeable. I've de-skinned several rear quarters from squaretails for use on roundies. it's a LOT of work but worth it.
& 1 special alfa
