Wheel/tires options for 73 2002 tii?
sansloy
I need to replace some shot tires (165-13) on my tii, and I'm getting pretty confused. The stock tires for my 13x5.5 steel wheels are 165-13, which tire rack currently doesn't carry.
If I was willing to get new or used non-stock wheels, does anybody know what will work on my model?
If I google 73 200tii wheel, I see people describing VW wheels that will work. I just want to get my baby up and running as cheaply (and safely) as possible.
Tire rack tells me that 15X7 with a 195/55R15 are viable options, but now I'm up to $800.
Thoughts
165-70-13 are still available, but you have to shop around. most local shops can order them within a day or 2, i currently run them on my E21. I used to run 205's because they look a lot better but I ended up preferring how the 165's fill the wheel well better.
If you have the money, i would recommend upgrading your wheels to at least 14" (they came stock with 14's) and you will have many more tire options.
79' 320i (comfy modified daily driver)
73' 2002 (weekend beater crusier/rolling resto)
73' 2002tii (superfast rust bucket undergoing restoration)
72' tii (parts car)  ...99' SV650  ...00' KTM 380 2 stroke ...06' Kawasaki Ninja 500R ...96' F-250 7.3L turbo diesel (towtruck)
I agree the 187/70 13 is a great size for the '02 and will fit very well on 5.5" rims. The steering effort is not much different than the 165 13's and it is a size that is still available from a number of tire manufacturers (I wish we could still get the 185/70 13 P3 Pirelli's)
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Where are you located at?
I got my last set of skinnies from Les Schwab tires. Pretty inexpensive as I recall.
the original tires on the 02's was a 155 or 165R-13. No profile aspect number usually meant they were like 78 or 80's. The stock skinnies are out there, but not as common anymore.
One option is to go up to 14" wheels. The E30 bottlecaps are a common choice and the offset is close enough to work. E30 steel wheels also work, but you may need to get creative with the center caps. Tire size for the 14" should be 185/65-14. I have not had any rubbing problems. Be careful, as most of the E30 wheels were shod with different sized tires that won't be ideal for your 02.
Steve J
& too many bikes
I'll add some dissent and say you should go to 15". The car can handle it and performance tires are much easier to find in 15" as opposed to 14". That being said, if you aren't going to put some extreme summer tires on and want all-seasons, then 13" or 14" will be fine.
- Justin
1973 2002tii
The toolbox is where truth and contentment lie... -James May
185/70 13's will fit your rims and tire rack has a few tires available in that size.
I like this size for ti/tii 5" wide wheel.
These tires are getting harder to find. During lunch, I looked at Tire Rack and Discount Tire. Not many choices there.
+1 on this size for ti/tii 5" wide wheel.
I always thought that going larger on stock wheels was +0?
And yes, I'll agree that 185/70-13 is the size to go.
Tom Jones
Geez - Tom you are tough! I'll edit my response just for you.
