Upgrades for a daily driver?
booksat
Looking at buying a '75 02, automatic w/ rebuilt engine and transmission, supposedly in turnkey condition. The car would often be used as a daily driver for short commutes and around town driving.
To be as safe as possible for my wife, I wanted to consider sensible upgrades.
I was thinking of LSD, brakes, and radiator.
Can anyone tell me the rough cost of these upgrades, and suggest others that are worthwhile.
This is what I would get.......
Pertronix or Crane Ignition upgrade $80 to $120
Steel braided brake lines $50
Upgraded brake pads/shoes $100
H4 headlight conversion $80
New suspension bushings $50
A LSD would be nice, but for a reliable daily driver I would purchase these items first and go from there.
David G.
1989 Volvo 240 Wagon "Da Brick" Daily driver
1992 Nissan Sentra SE-R "Hitomi" Sleeping. Waiting for NEO VVL!!
1976 BMW 2002 "Diana" The never ending project!!!
For what usage you described..
Brakes are best in class. Just make them new again, for that new car smell.
LSD = slippery when wet. Keep the open diff.
A good radiator is the stock jobbie, unless you're in arid climates. Just renew the system. All new hoses, thermostat, water pump, belt, flush and pressure test the rad.
Good tires and a well tuned motor. Clean the fuel tank and pickup screen. Add a third brake light and restored seat belts from Bluedevils here on the board.
This list will keep you beboppin around town safe and sound.
(O=o00o=O)
Actually, I'd start with the defroster fan. If it's not 100%, that's a big
fiasco for short hops... if you live somewhere wet, cold or both.
Even a little of both.
Then the Pertronix, and go through the dizzy while you're there-
a worn dizzy makes the car a lot less driver friendly.
And the carb, too- if it's not nearly new, it's worth at least
putting a seal and diaphragm kit into it.
Wipers- not usually a weak point, but when they go, life sux.
Rear defroster- see above.
Bright taillights- LED's might be OK, but bright, either way.
Brakes- yeah, for an auto, the bigger fronts are really easy to do,
and inexpensive for the time and money. Not NECESSARY, but if
you're in there replacing calipers and rotors anyway, all you have
to add are the hubs. If your brakes are fresh, well... I'd do other things.
Like door plastic.
Weatherstripping.
I'm thinking of things that make my car BAD in the weather....
Oh, good multi- season tires- they usually have better wet grip.
(if it never rains where you are, you can adjust to fit)
If it snows more than occasionally, the LSD would be a decent add.
(see, people who can drive in snow know how that whole 'locked rear'
thing works... or figure it out pretty darned quick)
But otherwise, on an auto, it'd be pretty low on my list.
Certainly nice, but by no means necessary.
If your wife likes driving, shocks for sure, and maybe sways and/or springs-
the stock car is pretty soft for 3rd world roads. If that applies to you,
then stock is good...
Did I mention defrosters and heating???
Oh, and a 320 radiator works too, if your stock one's shot.
Otherwise, I tracked a stock rad for 10 years- it was good to 90F+.
hth,
all the above and if you're living in a hot climate i suggest to add an electric fan to the stock belt driven fan. Especially when there's a high possibility of getting stuck in traffic in summer.
Plus a larger Alternator, because the standard won't /can't charge your battery enough on short distances, especially with lights/defroster on.
And while you're at it, take a starter from an M30 powered E32 or E34 - they're smaller, lighter, have more power and need less current.
new STOCK brake calipers, pads, hoses, and rotors
with new wheel bearings
check rear drums, shoes, and slave cylinders for leakage
ADJUST REAR BRAKES CORRECTLY
new points, rotor, cap - set DWELL with a meter, set timing with
a timing light
rebuild the carb, new STOCK exhaust system
new tires
all new gas and coolent hoses
recore original radiator
new tie rods, center link, idler arm bearings,
shocks, lower ball joints, upper strut mounts,
anti-sway bar bushings (ALL BMW STOCK!)
SERVICE/CLEAN/TREAT EVERY electrical connector, bulb socket,
instrument cluster - remove extrainious BS wiring and all non-original
BMW electrical HS (horsesheit) items
new seatbelts, larger seat mounting bolts with larger washers
Automatic Trans service (oil strainer, and control linkage cleaning,
adjusting, lubricating
new door latch ACORN's ($0.47 each)
install under hood sealing rubbers on inner fenders,
and on underside of the hood, and proper fire wall
drain tubes so wife does not get GASSED!
WELCOME and have safe fun
p.s. - rough cost$$?
Parts $2,500.... $3,000 + your Labor FREE
Someones Labor ? ......... $3,000 (depends on where you live
and who you find)
'64 R27 250cc #383851 18,000m
If the car still has the original BMW door brakes/stops replace them and save your wife's shins ! :) , also the doors from being dented when the door swings open and hits the front fender. See at link below.
Harry
www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,363390/
1975 BMW 2002 Taiga
2000 BMW M Roadster evergreen
Thanks to all for the great list. I'll sort throught it an make a list of priorities accordingly (not made of money here!).
The car will be driven in the wet, so that's an issue. Garaged in the winter to keep it away from salt and the rear wheel drive simply is poor for daily driving with any ice and snow.
New England, so terrible heat isn't an issue, but since it will be driven in the summer with the a/c, upgrading the radiator may make sense. Though, I guess before doing so we can see if it's necessary.
Thanks again.
Any additional ideas are appreciated.
Before you buy have it checked out by a mechanic who knows 2002s.
http://www.bimrs.org/2008MapPage.html
Then fix everything that is required to make the car safe, use OEM parts. The engineers at BMW built an amazing car they designed it as a daily driver. My Tii is stock aside from the Pertonix and is used as a fair weather daily driver...about 10K miles this year.
Preventative and routine maintenance is key, these are 43-37 year old cars, when well maintained they a incredibly reliable.
Andrew Wilson
follow CD's list, but put third brake light at the top.
the myths of LSD's being bad in wet and rear wheel drive being bad in snow are complete and total B.S. stock LSD's are much better in all conditions due to the added traction. rear wheel drive cars, especially with LSD's, are great in snow...IF, like any car, you put real snow tires on all four corners. however, exposing a 40yo car to new england road salt in winter is a sure way for the car to die an early death.
personnally though, i would not let my wife drive a 2002 as a daily driver. i want her to be safe. old cars have none of the modern safety features. abs/dsc/crumple zones/airbags/etc.
2xM3
dozen 2002 improvements based on 42 years of daily driving. If you can't lay your hands on the August and Sept 2011 issues, drop me an e-mail and I'll send 'em to you.
cheers
