Is this a good deal on Dual 45 Webers?
jdirecto
That kit is from Redline. You can buy from them directly but there are a couple of people that sell Redline kits like Top End Performance (www.racetep.com), Jam Engineering, they will match your best price (http://www.jameng.com/products/index.phtml?section=2). And Redline themselves, www.redlineweber.com/html/application_guide/BMW.htm You will probably be able to get it cheaper from them.
Regards
Jacques
'71 2002 Malaga, fun weekender
'70 2002ti Colorado, Restoration/money pit
'74 2002 turbo in my dreams, sideways...
There is also a guy selling Italian 45 dcoe's with linkages and manifold for $700 in the for sale section. Italian dcoe's were better built than the later Spanish ones. I would buy that, put in a new carb kit and then you have a better setup for less.
Regards
Jacques
My engine has 90mm pistons, slightly ported head with 284 Schrick cam, tii dizzy. I have the tii injection, but since my car is non tii I'm planning on converting to dual carbs. Will this setup work with a 45 dcoe dual carbs? What size jets will work?
I appreciate all the responses. Thank you in advance.
Joey
Joey
Dual 40's will be much better for your application. They will have better response at lower rpm's that chocked down 45's. Unless you plan on getting a cam >300' and 10:1 pistons soon I would say stay with 40mm.
Its hard to say what to use for jets, best way is to find someone with a similar engine and carbs and work from there, although it will still not be spot on but closer than guessing.
Dual 45's are for big cams that need to rev high, not a 284, or even 292.
Regards
Jacques
I have a nice set of mikuni 44s with the linkage and manifolds for $650. They were set up on a 2002.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,364566/highlight,mikuni/
Why must this be soooo tempting! In my opinion Mikuni's are a nicer carb since they dont need as much fiddling. I would love to run a set on my 02!
-Nathan
I have some dual 40 PHH solexs with manifold, link bar and airbox I can get you info on (as in to sell). They'll need rebuild and cleaned up some.
Email me if interested (JSWeese11 at Yahoo).
- Jake
Current: 1975 2002 Automatic - 2010 Tacoma DCSB - 1997 Buell S3
Missed: 1967 1602 - 1973 Inka 02 - 1983 533i - 1995 325i - 2004 530i - 2004 X3 - 1999 R1100S - 2000 R1100RT - 2003 3.0 Z4 - 2004 325Ci - 2008 328Xi - 2009 135i - 1999 E36 M3
