e30 oil pressure switch replacement
Paul7002
It's my Dad's 1988ix with almost 240K miles. He recently received some estimates for some work and the labor seems silly. Two hours to replace an oil pressure switch? I don't have the car so I can't go look where it is, but 2 hrs seems way too much.
Also 5 hrs to replace front struts and strut bearings/mounts. I know the ix is a bit more complicated than other e30s, but does that sound right?
Thanks,
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
The struts and bearings may be correct. Remember, on the ix you are dealing with half-shafts up there.
I'm not sure on the ix, but on my E30M3 the oil pressure sender is down on the block, behind the alternator. It does involve removing the air box, and possibly the alternator if you need to turn a wrench on it. But with a stock sender, I think a socket would work.
Take a look at RealOEM and see if the diagrams there give you an idea where it sits on the ix.
Steve J
& too many bikes
The switch is under the forward header
I think it is threaded into the oil cooler
Housing, it is easy to change. The struts
Are easy to service. A local repair shop
Can do both in one hour with a portable
Spring compressor. There is no reason to
Take the struts off for the bearings or
Inserts.
Good luck
Stone
stone racing co
phila pa 19123
