Contemplating selling unfinished project $10K FIRM
skipsfcr
Will take photos soon but for now, read.
The car is a true sacrafice at this price.
1973 BMW 2002 non-sunroof 4-speed
zero miles on all items listed, only test driven once, unpainted, to test engine / driveline
COSMETICS:
New riviera paint. (Traded ’95 HD 1200 Sportster for paint) door jambs & hood latch cover need touch-up
Rear bumper mounted with ’72 bumper brackets
Front bumper (not mounted - needs ’72 brackets) ’73 bumper with overriders in nice, driver condition
New Aamco (sp?) front bumper bar, used rear (decent) not installed
New kidney grille
Decent side grilles (driver quality)
New euro front turn signals & gaskets
New (raised type) roundels & “2002” emblem
Nice flag mirrors for both sides of car (right door not drilled yet)
All new plastic trim clips & stainless Rimspoke clips, many already installed
Many beltline & knee mouldings installed “decent” driver quality (subjective)
New trunk gasket (not installed)
New windshield gaskets (not installed)
New cowl drain tubes installed
New hood seal installed
New hood side seals (by hood latch bar) not installed
New aftermarket hood insulation installed (3 pieces)
Spare tire well rusted through (planned on patching rather than whole trunk floor)
Have virtually everything else needed to complete the exterior except a few pieces of trim
UNDERBODY:
Rear sub-frame powdercoated, new sub-frame mounts installed
Trailing arms powdercoated, new stock bushings installed
Rear (stock) springs powdercoated
New Boge (OEM) rear shocks
19mm rear swaybar installed with stock rubber bushings
Rear brake backing plates powdercoated
Rear differential upper mount nicely painted, bushings used but excellent
Front sub-frame powdercoated
Front control arms and strut rods powdercoated, all new stock bushings installed
New ball joints installed, bolts thread-locked, torqued, and tie-wired
New tie rod assemblies, new center link, new idler arm bushings
Pitman arm powdercoated
Front strut housings powdercoated
Front (stock) springs powdercoated
Excellent used Bilstein strut inserts installed (will include NOS Boge front inserts & hardware in sale)
19mm front swaybar installed with stock rubber bushings
Front disc brake backing plates powdercoated
WHEELS, TIRES, and BRAKES:
Repainted 5X13 stock steel wheels including spare (Mike Wooldridge)
New Kumho 185-70-R13 tires, new valve stems and factory BMW valve stem caps
Excellent factory chrome wheel covers with new emblems installed (Mike Wooldridge)
New ATE front brake rotors
New front wheel bearings and seals installed with Mobil 1 grease
“New” factory remanufactured front brake calipers with organic pads
New ATE rubber brake hoses (4 front , 2 rear)
New rear brake hydraulic wheel cylinders
New Textar rear brake shoes
Refinished & repainted rear brake drums
New parking brake cables installed
New rear wheel bearings & seals installed with Mobil 1 grease
New ATE brake master cylinder
New cloth braided brake fluid supply hose
New brake fluid reservoir
ATE Super Blue brake fluid (I’ve had good experience with it)
ENGINE, COOLING, and EXHAUST:
Engine completely rebuilt (except used tii pistons installed) does not match VIN of vehicle
Used, standard bore 9.5:1 Mahle piano top tii pistons installed
New standard bore Goetze piston rings
Block precisely measured to accept pistons at standard bore with light honing
Block chemically cleaned, freeze plugs replaced, and painted black
Crankshaft polished standard
Connecting rods resized, new wristpin bushings installed and honed
Rotating assembly meticulously assembled with Glyco rod and main bearings
Cylinder head cleaned, inspected, and lightly resurfaced (with upper timing cover)
Valve job performed, new valve guides installed with Viton valve stem seals
New intake & exhaust rocker shafts installed
Korman 292 degree reground camshaft
New stock exhaust studs installed using thread sealant
New stock head bolts
New Iwis double row timing chain, new OE camshaft & crankshaft sprockets
New timing chain guide, tensioner rail and tensioner piston & spring
New Febi / Bilstein oil pump installed and shimmed
New Iwis oil pump chain & OE sprocket, locknut, and washer
New Hepu water pump
New BMW “tropical” 400mm fan blade
New Continental alternator belt
Entire engine assembled using Victor-Reinz upper & lower gasket sets
New stock engine mounts, block brackets painted
Stock exhaust manifold vigorously cleaned & installed with E30 M10 heat shield exhaust gasket
New stock replacement center exhaust section and rear muffler
All new exhaust mounting hardware properly installed in stock locations
Stock radiator professionally cleaned / rodded, painted, and verified leak free
New 180 degree Wahler thermostat
All new cooling system hoses installed with modern BMW (Wurth) hose clamps
All peripheral engine components media blasted & repainted
New Bosch Super’s, plug wires, cap & rotor
New Hot Spark points replacement ignition module
Weber 32/36 DGV with Sync – Link synchronous conversion from Pegasus Racing
(I intended to replace this with a new Weber 38 DGES)
Air cleaner adapter for stock two bbl air cleaner to Weber
Nice stock breather with new air filter
All rubber fuel hoses on vehicle replaced
Remanufactured Bosch 70A internally regulated alternator
New battery (has been sitting)
TRANSMISSION & DRIVELINE:
Excellent used 4 speed transmission cleaned & repainted (so-so paint)
60,000 mile +/- driveshaft removed from Larry Wilson’s (IN) incredible schwarz ‘75
New guibo joint & center support bearing
Rebuilt late type shifter mechanism, new floor insulation donut, wooden BMW logo screw-on shift knob
New Sachs 215mm clutch kit (Disc, Pressure Plate, Throwout Bearing, and Pilot Bearing)
Resurfaced E30 M10 215mm flywheel (lighter than ’02 215mm unit)
New ATE clutch master & slave cylinders
New slave cylinder hydraulic hose
Stock 3.64:1 rear differential in excellent condition. Cleaned, painted, new cover gasket
All rear axle joints cleaned & repacked, all C/V boots & clamps replaced
All axle hardware installed with thread-locking compound
Appropriate Redline oils in transmission & differential
INTERIOR & MISCELLANEOUS:
New speedometer cable
New Al “Blue Devil” Erkanli front seatbelts (not installed)
New blower motor (came without blade, balance may be off slightly) works fine
Blue door panes DO have speaker holes unfortunately, as does rear deck
New PKB rear parcel shelf
New Esty carpet kit, blue (I was going blue on blue in this car – not too late to go with black)
All instrument panel bulbs replaced (not sure about odometer gears)
Original headliner in decent shape (one tear needs to be repaired)
Decent original long, non-A/C console (not installed)
Period correct Blaupunkt AM/FM stereo (not installed)
Correct, early used rear seats, blue (not installed)
’76 tan front seats & nice sheepskins (driver’s seat upholstery split / passenger’s nice - was planning to SEM spray them blue)
Dash has a crack in it (not terrible)
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
