1972 roundie project for sale, Los Angeles Area
DONK
Started project several years ago and still working on it. Things done to the car so far:
Replaced entire cooling system. New thermostat water pump hoses radiator (used) and fan. May need a thermo switch. Leaks out of one hose but easy fix just tighen hose. Also there is an alternate leak somewhere underneath....may be the radiator plug. Also replaced mechanical fuel pump. Engine runs perfectly when heated up. There may be a problem with the starter draining too many amps from the battery as it starts several times when the battery is fully charged but then doesnt start after that ...have tried it on several batteries.
Replaced alternator (rebuilt) and battery. Rebuilt original solex carburetor. and replaced throttle spring.
Exterior: sanded down to bare metal and replaced bondo...Previous owner had entire car covered with approximatiely 1/2 inch of bondo and painted with what appeared to be house paint. Replaced both doors to avoid extra sanding. Have original and heated rear windshield, replaced rear trunk and hood. Exterior is primered and nearly ready for paint. Purchased a n extra set of rear quarter glass and have brand new glass seals all the way around. Tires need replacing but I have original hubcaps that look brand new to put over original steelies. Have both original bumpers but previous owner removed all the chrome and painted them black.
Interior is trashed. Reinforced flooring with new stainless steel panel welded into the original floor. Floor was then covered with rhino lining. Originally there were only two small holes one int the drivers side and one in the passenger side. Replaced entire floor for protection. I also have seats from a 76 that are in immaculate condition as well as an original steering wheel in like new condition.
Entertaining offers but must see in person....no over the phone offers.
kvashay@hotmail.com
