Exhaust hanger help
bnam
The exhaust on my 74Tii was clanging and when I checked I saw that it did not have a rear-most hanger and was held by zip ties. So I ordered a couple of new hangers and inserts and went to install it today. This is what I found:
and the one near the diff:
Searching thru the parts diag on Max -- it looks like the hanger mounts on the exhaust need to be flat vertical pieces that then mount within the plastic inserts -- not the round ones that I have. :(
Do you think the exhaust guys could fab me up something?
Or, does someone have an old exhaust they could cut off the mounts from and send me?
THanks!
Byas
any good exhaust guy can make what you have work for cheap. you wont be able to use the bases with that aftermarket set up but 2 reinforced rubber hangers like you bought and a couple home made welded brackets and youre set
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
see , this kind of botching leads people trying to re-botch
with more welding on of StUfF that doesn't match, can't make
fit with more issues.....
Put the car back to Original Stock Quality and never have to
crawl under there again - and you'll improve the value of your car
at the same time! YIKES!!
'64 R27 250cc #383851 18,000m
I agree -- and my intention is to change back to stock or one designed specifically for our cars. Just that there are so many such hack jobs that I need to prioritize what I need to buy right now and what I need to band-aid for a while longer. :(
If someone could post a pic of what the mounting brackets look like on that rear exhaust piece, I'll try to get a local exhaust guy to hack up something closer to the original.
Thanks!
Byas
