DIY Kfish tools
bnam
Since I need to resynch my Tii pump and throttle, I need to DIY the tools.
2 of the tools seem to be easy to do -- incorrectly labelled in the KFish manual in the pic posted by CD where they are referred to as the 4mm pin and the 5mm hook -- my measurements show that they are actually 3mm pin and 4mm for the hook (Haynes has it right). These 2 are easy to do.
The flat tool that goes under the cone, how thick is it? Does anyone have measurements for this one?
Thanks!
Byas
'64 R27 250cc #383851 18,000m
Let me finish my coffee and I will waddle down to the shed and find out.
The Site Search up and to the far right using "homemade tii tools" returned this.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,283356/highlight,tii+tools/
See if that gets you started.
If my memory serves, I cut the long cuts with a cutting wheel on a die grinder. Made it flex until it bent and broke, then I used many success cuts with the die grinder to make the rounded part.
1972 2000tii Touring #3422489
FAQ member #5
CD,
Hope you didn't read my prior note to mean that I was being critical of what you posted. As a newbie here, I find the diagrams very helpful and save whatever I come across for reference. I saw a lot of references to the pin as a 4mm pin -- the Kfish manual, the diagrams you posted, the Tii registry info, etc, so was very surprised when I measured the hole and found that it was only 3mm.
Bill, CD,
Thanks for the link/measurements and the right search terms. I searched for "Tii tool" and did not see the link Bill posted in the first couple of pages.
Byas
