1975 BMW 2002 Silver w/Black & White interior - $2550
Gram75BMW02
GOOD:
-Newer metallic Silver paint
-Many parts from ‘80s E30
-Engine
-5spd transmission
-Rear differential
-Driver / Passenger seats
-Rebuilt Weber carb w/bearings in place of bushings
-Momo steering wheel
-Clean black & white perforated vinyl interior
-Ran without issue prior to disassembly
BAD:
-Fuel tank removed and carter electric fuel pump partially installed
-Oil pan is off the engine, replaced E30 oil pump / pan with original 2002 M10 parts
-IE baffle welded in oil pan and has fresh powder coat & IE windage tray
-Rear exhaust mount is broken, so the muffler dangles pretty low (See photos)
-Body is a little rough, appears to have had light front and rear collisions
-Holes in floor pan below the drivers and passengers
Here is a list of everything included with the sale:
-1975 BMW 2002 (As described above) – paid $3400
-New M10 Oil Pump from Bavarian Autosport (Installed) – paid $347.60
-Carter ‘Street’ electric fuel pump (Installed behind tank, but fuel lines have not been connected) – paid $108.97
-Weber carb rebuild kit with bearings (Installed) – paid $44.90
-IE urethane motor mounts (Installed) – paid $92.00
-IE urethane transmission mount – paid $35.00
-6 bolt drive shaft guibo – paid $44.00
-IE urethane steering coupler – paid $20.00
-IE oil pan baffle (Welded in pan / powder coated) – paid $35.00
-IE windage tray – paid $45.00
-2x oil pan gaskets – paid $11.90
-BMW 2002 Haynes Manual – paid $20.00
-Bosch Fuel Filter – paid $14.00
-ITG air filter / baseplate / breather – paid $130.00
-IE stage 1 sports springs – paid $261.70
-Bavarian Autosport 2002 radiator upgrade kit / 400mm engine fan – paid $310.90
-Street underdrive crank pulley – paid $75.00
-Replacement gauge cluster (Installed) – paid $92.75
-McMaster Carr parking brake bearing kit – paid $20.00
-4x E30 steel wheels w/fresh powder coat – paid $290.00
-16pc chrome lug nut set – paid $27.38
-New front brake calipers (Installed) – paid $200
-Braided steel brake lines (Installed) – paid $98.78
-Misc hardware from Maximillian Import – paid $59.00
-New fuel tank from Maximillian Import – paid $435.00
I am into this car around $6500 and just have too many projects and too little time. Some assembly time and new battery will have this good looking driver back on the road. Feel free to contact me with any questions.
Thanks for looking, Jason
jlgraham@hotmail.com
See photos at:
https://plus.google.com/u/0/photos/110482168978474828691/albums/5702214392262990081/5702214468956362114
http://orangecounty.craigslist.org/cto/2820434773.html
