Can you recommend a replacement steering wheel ?
deschodt
Recommendation on getting the OG steering wheel nut off---thing won't budge!
Also, just to clarify the socket is 22mm.
Derek
What I had to do to pop it off was get a long 22mm socket and have me and my dad hold onto the wheel countering the pressure to not snap the steering collumn lock while he toruqed it loose. Mine was really tight too.
76' Fjord Daily SOLD
1986 528e 5 speed Daily
"I don't have a piece of sh*t so I have to envy yours!" - Ferris Bueller
Lefty loosey, correct?! I use the 1/2" ratchet & a 5" extension with the 22mm socket. You can keep the wheel locked (key out of ignition) to crank the offending nut counter-clockwise, but you run the risk of damaging/breaking the steering lock mechanism. Consider a breaker bar (e.g., jack handle) over the end of the ratchet, for more leverage.
John in VA
Derek
I use a 2 foot breaker bar and hold the steering wheel. Doesn't need to be super tight when it goes back on.
Here's my steering wheel, it's a CS Coupe wood rim wheel I restored and modified to make the horn work.
It has the same dish as the stock bus wheel and is 2-3 cm bigger.
post-38744-0-92259900-1413599463_thumb.j
Andrew Wilson
Derek
Impact gun worked awesome yesterday. Zip zip, done.
Brent
1974 2002 - Megasquirt and turbo
2018 BMW M2/ 2013 Porsche Cayenne Diesel
This in my Jackie Stewart Momo. It's a little on the small diameter side but so far I like it. I had one like it before but has silver finished spokes and is in real rough shape. Horn works sometimes, I need to look into it. Turn signals work fine.
e2723eaf22ee9ea5b3d01cbb269294dd_zpsd826
John
1665778
Do all nrg wheels fit on momo hubs?
Just Googled your question and got this:
MOMO Hubs will also fit SPARCO OMP NRG SABELT ISOTTA steering wheels, all MOMO Hubs have six bolt mounting pattern, the distance from center to center of the facing holes is 2.75" You may loose the horn and the turn cancel feature on some cars depending on the electric wiring of these cars.
from this link:
http://ltbautosports.com/momohubadapter.html
