Fuel Hose sizes
Dachdu2002
Standard 2002's should use the same 8mm I.D. fuel hose. Tii's have a larger fuel supply line from the tank to the electric pump.
Wild guess on the lengths (carby guys please correct me):
Fuel tank to plastic line running thru body: 2 ft.
Plastic line at front to fuel pump: 2 ft.
Fuel pump to carburetor: 1 ft.
Tii's:
12mm Fuel tank to electric pump: 3.5 ft.
8mm Pump/accumulator to metal line near D.S. wheel: 4 ft.
8mm for Metal line at front to fuel filter: 2 ft.
8mm for Fuel filter to KF pump: 12"
8mm for KF pump to cold start valve: 2 ft.
8mm for KF pump return to firewall: 3 ft.
8mm for plastic return line at rear to fuel tank: 2 ft.
8 x 13 mm hose everywhere ............, except at some mechanical
fuel pumps - one fitting maybe smaller so a 6mm~8mm brass
barbed adapter maybe needed and a section of smaller i.d. hose at the pump.
'64 R27 250cc #383851 18,000m
I have a '71 and just replaced the fuel line between the tank sender and the plastic fuel line that runs through the trunk. I used 1/4'' (6.4mm) which provided a better fit than the 8mm. In the engine compartment, there is a plastic push on fitting over the plastic fuel line as it exits the firewall. That is a little larger and the 8mm works fine between it and the carb.
