Exhaust header design question
bnam
PO had installed a 4-2-1 header on my 74Tii -- allegedly from IE. But, I could not find a matching pic on their website.
The header on mine has cylinders 1&3 and 4&2 paired together. IE site says (wrt shorty header) that 4&1 and 2&3 is the correct pairing. But, their stage 2 header shows 1&2 and 3&4 pairing. I initially thought I had the stage 2 header until I noticed the diff in the pairing (unless IE changed their design sometime).
So, which pairing is right and which one is worst?
Thanks!
Byas
Looks like an old Alpina bag of snakes copy. The design was to keep all the tubes the same length!
-Nathan
For torque, you want 1&4 paired with 2 and 3-
it balances out the pulses over time, as your zundfolge is 1342, you know...
any other pairing in a tri-y will be a net loss.
I found
http://www.alpinabmw2002.com/2010/03/schrick-bmw-m10-headers.html
had a couple of pics of Shrick copies of Alpina bundle of snakes. Though the first set has pairing similar to mine, while the second is 4/1 + 2/3 pairing.
If the 4/1 & 2/3 pairing is better for torque, why is the IE stage 2 paired as 2/1 & 4/3? Is that for peak hp?
Thx!
B
You are mistaken. The IE short headers are designed with the correct 1&4 and 2&3 connections. See the description on our website.
Jeff Ireland
There is no such item as a "stage 2" header from Ireland Engineering. We do not make any 4-2-1 header other than the shorty. Our long tube headers are 4 into 1. You must have us confused with a different manufacturer.
Jeff Ireland
Sorry you have mis-read my post -- I said your shorty headers have the "correct" pairing, but was wondering if why your stage 2 headers have a different pairing.
http://www.iemotorsport.com/bmw/2002-exhaust/02stephead1.html
Thx!
Byas
i think you're mixing two different designs up:
4-2-1 need the 1/4-2/3 pairing
while 4into1 headers can be paired as space allows whereas it's important all pipes are the same lenght
Sorry my error. I looked at our website. I guess my guys have decided to call the 4 into 1 long header stage 2. The fact that the tubes end up beside each other at the collector does not mean they are arranged 1-2 and 3-4 . It is not significant. The tubes are in a bundle so each tube touches all the other tubes.
Jeff Ireland
Found this in another thread today. Original source was CD
The top header has 4&2 paired -- I think I may have found the origin of my header.
Anyone have anything good to say about this Ansa header?
I had installed Ansa on a Fiat spider many years ago and I remember it went together very easily and hung/fit well.
Thx,
B
Thx,
B
I believe is is a copy of an Alipna initially. The reason for the funky look if I remember correctly is to have all the tubes the same length, I believe it is for better torque.
-Nathan
