tii engine clearance questions
jgerock
On mine, I get 3/4" from fan hub to (3 core) radiator, and 12 1/2" from firewall to cl of center cam cover acorn nut.
I know the nose on mine has been replaced once.
Stock 4-speed.
1973 tii, agave, since 1992
1973 tii block 2763759
1967 Mustang GT fastback, since 1986
1999 Toyota 4Runner, 5 speed, ELocker, Supercharged
Measurements on my car. Nose damage at some point. Drive shaft too long.
From radiator cap, 26"
Firewall is contoured -- so where you position the tape can throw off the reading by about 3/8"
Measuring from a lower point on the firewall, I get just over 12" to the roundel center - -so my engine is about 1/4 forward of yours...
My radiator is a bit askew with the closer point being the pass side where there is 3/8" clearance to fan
while the center is about 1/2" clearance at blade and at hub.
Radiator gap seems similar.
Couple more reference points possibly for engine location
My pass side mount has no gap (again consistent with being a tad forward of your engine.
Does this look like there was some welding done?
And, while my engine seems to be similarly located to yours, I was able to get the Airbox aligned to throttle body. I think you should be able to as well.
And, gap at the top of the radiator is about 1/2"
So, it puzzles me that despite the radiator being the same distance from the firewall @ 26 inches, AND my engine being a tad forward of yours, it has more clearance to the radiator.
Byas
Thanks for all the measurements guys.
Byas-
My radiator core measures 1.53" thick and 1.676" thick at the widest point (metal casing to mounting bracket - not the tanks). The position of the mounting brackets on the core makes my radiator push in toward the engine.
The distance between the water pump pulley and fan hub looks smaller than mine (1/2"). The spare 5-blade fan I have has different "sides" to the hub, one side measures 5/16" deep, the other 5/8". Theoretically, you could install the fan backwards and space it toward the radiator. I compared the spare fan to the one on the engine (blades are oriented the same way) so I think it is on the correct way. Air is pulled thru the radiator.
Older picture before the 5-speed swap.
Not that it matters, but my radiator has a temperature switch on the lower LH side for the A/C system. Maybe from a later model??
Jim
Dug out my Silicon Garage radiator this morning and took some pics. Per my call to Mark when I bought this unit, my car has a "late model" radiator that can accomodate a fan shroud and has an NPT drain plug in the lower side.
I bought the same unit from Mark intending on putting in my tii, but am saving it for another car.
Core thickness
Overall thickness
This radiator looks exactly like the one in my car (except for number of rows).
Byas-
Jim
Jim,
I'm confused. The third pic in your first posting showed a 1/4" gap from you fan hub (5-blade I believe) to the radiator. Your above note states you have 1/2" clearance.
Assuming it is 1/4" clearance,
I see the following measurements --
Radiator to firewall is same distance -- 26"
Your engine is 1/4" back vs. mine
Yet I have 1/4" more hub to radiator clearance.
I can't explain the 1/2" (1/4"+1/4") discrepancy. I probably missed something.
Byas
Byas-
Jim
Jim,
Byas
Sorry Byas..
I am referring to the distance between the fan hub and the water pump pulley (1/2")
Hey,
i have recored many radiators using the same cores
that come from si garage. your radiator sides are mounted
too far forward of the core. when i have the sides
soldiered on i have the core set nearly flush with the
part of the side that attaches to the nose panel. the
wire loom over the top is tight but it gives the best
fan clearance. most motor's tilt toward the radiator
in a hard braking action. i have seen a few fans eat
the tubes or flatten the fins after these actions.
if you can find a good radiator shop they can fix the
location of the sides.
good luck
stone
stone racing co
phila pa 19123
FWIW, Jim...
-Distance from the firewall to the center of the roundel in the intake on my car is about 11 7/8 inches (which looks the same as yours - or at least pretty close).
-The distance between the hub of the fan and radiator on my car is 3/4 inch - pretty big difference.
Scott
02ing since '87
'72 tii Euro  //  '21 330i x //  '14 BMW X5  //  '12 VW Jetta GLI
  • 1 year later...
Hi all,
i have a similar issue, except that I am finding that my radiator fan (originally 360mm) had to be trimmed down to about 300mm to avoid having the bottom of the radiator being brushed by the fan.
I've already changed the engine and trans mounts - but cant figure out why i am having this issue.
I've been finding that the reduced fan diameter is really affecting my cooling ability - and have a tropical fan blade ready, just cant install it without it getting destroyed.
Any suggestions?
When I rebuilt my engine a few years ago, I installed a new water pump. I had clearance problems that I eventually traced to the mounting flange being too far forward on the impeller shaft. not exactly an easy fix as it requires radiator removal, water pump removal etc.
Gale H.
71 2002 daily driver
70 2002 malaga (pc)
83 320i (pc)
