accelerator put-put-putting
Hello all, in need of help.
Yesterday while driving my accelerator pedal began to fail. It started coming in and out, losing rpms at quite a rate. I even had to restart it while rolling at 35 mph multiple times. This seemed to happen more in higher gears.
I've got a Weber 32-36 that has a cold start issue, and I feel like this might be a related problem.
Any ideas?
1975 Inka 5-Speed
There could be a number of things contributing to this situation. I'm guessing that your linkage is OK - that you've checked to make sure it's not the ball-nut coming loose at the back of the carb.
If that's not the problem I'd be inclined to check that your idle jet is not clogged. It's easy to remove from the ouside and visually verify that it does not have a small spec of rust, etc. clogging things up. A strand of wire from stranded-wire can be used to carefully make sure it's free and clear.
If these do not solve your problem, come back on here (stating what you've already done) and we'll see what else we can suggest.
One more thing, if you have an electric choke be sure you're getting 12V to the choke. Could be you've got a bad fuse.
Bob Napier
almost dead fuel pump
dirt in the carb
crud & rust blocking intank strainer
porus leaking gas hoses
something wrong with the float inside the carb
something wrong with the carb jets
something wrong with the ignition
............ for starters
'64 R27 250cc #383851 18,000m
The "idle" jet circuit actually supplies most of the fuel up to around 2000 or so rpm before the main jet circuit kicks in.
And if you clean out your idle jets (there are two) with a piece of wire, be sure and use copper wire--it's softer than the brass jet and won't enlarge the hole. Since they're sized in (nominal) .01 mm sized (a 45 main jet is nominally .45mm in diameter) it doesn't take much poking with a steel wire to make a 45 jet into a 55 jet--and booger up your idle for sure.
If it's not fluff in the idle jet circuit, I'd look for an intermittent vacuum leak. If your dizzy has a vacuum advance unit, make sure when you suck on the vacuum hose you feel resistance--otherwise the diaphragm is shot and that will upset both mixture and timing.
cheers
