fuel Tank
Rob S
'69 2002; '04 330i ZHP; 2018 X1; 2014 535i; 2017 340i
take the tank to a good radiator shop and have 'em check it. The proper way to repair is to fill the tank with either carbon monoxide (from a car exhaust) or CO2 (not water) and then solder up the leaks. Had mine repaired after a piece of road debris punctured it--they soldered a penny over the hole. Still good after 25+ years.
If you do replace, make sure you get the same tank--there are many variants--by year, tii vs carb, long or short filler neck etc...
cheers
I just had to replace one myself and their easy to find but a bit expensive Shipping is also very expensive because of the size. I suggest fixing the leak, it will be much easier and less expensive.
I've survived damn near everything.
1974 - 2002, Mild - sold to son
1976 - 2002, lil' Wild
