Taylormade burner 2.0 combines wisdom with strength
Natural Golf easiest to a swing method, the easiest, most natural, most suitable for your personal characteristics, Natural Golf is based on the uniaxial and single swing plane, emphasis on simple and natural swing, swing by using a simple way to remove the complexity of the professional swing, leaving players to concentrate on hitting. Before you hit TaylorMade Burner SuperFast 2.0 Driver, read the Natural Golf, you can do a better swing than ever.
2.0 driverr was able to better interpretation of Natural Golf. Practice with the driver, you will get a longer distance on the tee, and you will feel more confident .
The advantage technologies of the driver are not as its appearance. Even if the sample outward appearance, we also can feel the great technologies form the taylormade burner 2.0. The driver has a deeper face and low and deep center of gravity (CG) to promote a higher launch with less spin to help result in an increase in distance. Ultra-thin Wall technology on the inside reduces the wall thickness in the clubhead to allow for a larger face up front. This creates the biggest face on any TaylorMade driver which gives you a larger hitting area with a larger sweet spot for more forgiveness. The burner 2.0 Driver offers exceptional distance with extremely light weight. Every design was used the core technology of TaylorMade. Combining wisdom with strength, do not miss the great driver.
