recommended tire pressure
JohnS
I just installed new tires on my daily driver (Sumitomo HTR T4 185/70 R13). What tire pressure should I use? I currently have them pumped up to 32 psi. Is that too much? Thanks,
John
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
32 all round? no that's good
or back down to 26 psi all round and see how that feels
depending on the driving conditions, your suspension,
tire construction/size, tread wear pattern, alignment?
you may need to have a different Front/Rear setting..
Front/Rear
26/26
28/28
30/30
32/32
26/28
28/32
34/30
36/30
all depends on many factors
'64 R27 250cc #383851 18,000m
Thanks CD,
Makes sense. I think I'll lower it down to a cold pressure of 26 for both front and rear to see how that feels. Car has a suspension package (anti-sway bars front and rear, shorter springs, shocks, fixed camber plates) that Dinan used to sell that uses their custom valved Bilsteins (somewhere between sport and HD). Thanks,
John
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
I ran 30 all around when I had 13's and 14's. When I went to 195/50R15's I went to 35 on all corners which works out pretty good.
-Nathan
I run 185/60 Dunlop Direzza Sport Z1s on 14 x 6 wheels and use 32# front and 30# rear. This is with shortened springs, 19mm bars front and rear, and HD Bilsteins. The lower rear pressure helps the rear end come around a little better, since I have the same size bars front and rear. I'd prefer a bigger bar in front (by a couple of mm), but this is what I have.
I base this on a ton of autocross experience with boxes full of trophies. I have two Porsche Parade class wins (in a 356A) and a BMW CCA Oktoberfest class win (in the tii class, though my car is not a tii).
Bob Napier
John,
For what it is worth I regularly run 30 psi in my 195/60-14 Sumitomo HTR 200.
Earl
74 02Lux
02 M Roadster
72 Volvo 1800ES
74 02Lux
15 M235i
72 Volvo 1800ES
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell
