Valve adjustment
I bump the starter and adjust which ever one is on the back of the lobe.. It CAN'T matter.
This, I do 4 at a time then the last few as I go.
-Nathan
I just went thru this process last weekend. I first started with going cylinder by cylinder at TDC and doing both Ex and In at the same time. I then happened to check a couple of valves as they were more directly at the back of the cam and noticed that they were looser than what I had set them to. So I went thru again and this time adjusted when the follower was ~180deg from the cam peak.
Byas
