1976 BMW 2002
prochase
A stunning example of the last year imported. Previously owned by an airline pilot and doctor and has been garaged its entire life. The body is in beautiful shape with all straight panels and correct gaps. The car has been maintained above and beyond factory recommendations and to a very high standard. There is no rust anywhere and no rust has ever been treated!! The car has never been wrecked and is the desired factory sunroof and A/C model. A beautiful, original example of the last year imported. Mileage is approximately 104,XXX. Particulars are as follows:
Body/trim
2011 bare metal repaint in original Sahara color, 2 stage PPG paint computer matched, not overly polished and has the look of original enamel
All the following items replaced with OEM from BMW Mobile Traditions:
Front windshield
Front turn signal assemblies
Rear brake light lenses
Sunroof felt trim
Rubber gaskets – trunk, rear window, front window, door, ¾ side window complete, windshield wiper, door handle, side mirrors
Exterior trim – belt moldings, lower door guard trim, ¾ window trim, rain gutter, vertical side trim, center grill, front emblem, rear emblem, 2002 script
Aluminum bumpers striped and re-anodized
Rubber bumper covers in excellent condition
Factory front license plate
Interior
Front and rear seats re-upholstered in original leatherette material
New carpet with Dynamat installed throughout
New headliner
Refurbished door panels and handles
Recovered rear shelf
Recovered spare tire & gas tank panels
All interior & dash lights work, all gauges work
Functioning fan & heater controls
Functioning Behr A/C
New shift boot
Engine/Transmission/Differential
Factory BMW long block replacement with approximately 10K miles usage
New Weber 32/36 carburetor with manual choke
New alternator
New starter
Rebuilt distributor
New radiator
New engine thermostat
New gearshift selector bushings
Transmission shifts smooth with excellent clutch operation
Differential is quiet with no howling or rumbling
New exhaust resonator and muffler
Recent transmission fluid change
Center bushing and guibos in excellent shape with no driveshaft vibration
Steering/Suspension/brakes
Recent pad and shoe replacement, brakes are excellent
New front wheel bearings
All front and rear suspension, transmission, rear differential rubber bushings in excellent shape
Bilstein front and rear shocks
Original springs – factory ride height
Steering box adjusted to factory specifications
Recent lower ball joint replacement
Steering is tight and ride is compliant and not too firm
Wheels & Tires
E-30 Basket weaves with new 185/60/14 Yokohama AVS ES 100s
Original 13” steel wheels with period correct Michelin tires
Misc
Complete factory tool kit
Original starter/locking keys
Factory jack & lug wrench
Factory manuals (reprint edition)
Haynes manual
All lights/turn signal work
Windshield wipers work
Horn works
No radio, but speaker wires were run to the back seat during carpet install
Comments
Car has not been modified in any way and can be returned to factory stock specification by bolting on the 13” wheels and installing an original Solex single barrel carburetor and air cleaner.
The only items that I am aware of that do not work are: Drivers side door brake, windshield washer pump and the odometer, which recently stopped logging.
47 Super high resolution pictures may be found at:http://s1225.photobucket.com/albums/ee398/prochase/BMW%202002/
$13,500 OBO
Eric Prochaska
Gulf Breeze, FL
T (850) 602-8656[/u]{option}[/img]
