Remove warmup regulator tii
Andy74tii
I'm removing my warmup regulator to check for coolant sludge and so on. To me it appears that I do not have to remove the "top hat" at all, just undo the mounting bolts and the brackets, is that correct? I do not want to disturb the position of the washer or the orientation of the shaft if I don't have to, in order to remove it.
Thanks,
Andy74tii
FAQ Member #126
Do check to see it is properly adjusted as well.
At 68F the piston that rises up on the regulator (the one with the slot in it) should be flush with the top of the regulator. If it is not, it can be adjusted - search for post from me on how-to.
Then check the gap at the enrichment screw.
Byas
