% CO to AFR
yes sir.
but another important goal whan adjusting idle mixture is
adjusting the Co% so that you have the lowest HC ppm reading.
The HC ppm reading raises with with too lean
or too rich - on each side of the optimun middle
so 2% Co might cause a lean misfire and high HC ppm reading
and 3.5% Co might cause excessive rich idle and also high HC ppm
reading. So probably 2.75% Co would give the lowest HC ppm
reading. HC is unburned hydrocarbon - BAD
Having a vacuum gauge T 'd into the booster hose
will also agree with the lowest HC ppm reading.
Optimum idle mixture adjustment will result in the highest
idle vacuum reading (approx 22 ...24 in.)
Now when you come off of idle - thats another story......
'64 R27 250cc #383851 18,000m
