Adjusting "Verboten" screw
bnam
You can't change AFR at WOT really without affecting the whole pump/range.
You site idle with the CO screw in the tuna-can
Hence the little modification (Wes ingram "sport" modification) where you can engage the warmup circuit a bit and enrich things slightly at mid-top end.
You could try gradually increasing fuel with the verboten screw a bit, but i think you'll find low speed / light load will be too rich.
FYI I'm at 13.0 AFR at WOT with a 2.2L and a mild cam.
Also double check your exhaust, an airleak there can also cause somewhat lean readings. I had a crack in a header that messed up my readings a bit earlier this summer.
-Justin
Had not though about the exhaust air leak. I have a 421 header with joints where the 4 go into 2. I'm assuming only joints/leaks upstream of the sensor will have any impact and a leak in the joint just aft of the gearbox will not impact the reading -- or will it?
Byas
