Ball Joint Pitman Arm
savvy
How does one remove the ball joint from the strut end of the pitman arm?
I removed the cotter pin from the castle nut.
I removed the castle nut.
I placed the forks of a ball joint tool in between the ball joint and pitman arm and placed the press arm on the top of the threaded end that held the castle nut.
I rotated the bolt on the ball joint tool so much that the threads on the ball joint stud began to crush and the puller bolt began to bend.
However the ball joint itself did not budge.
What am I doing wrong?
How does one do it correctly?
Cheers!
Cheers!
Savvy
'65 BMW 1600 4dr-not quite road worthy, but closer
'34 Ford Fordor Deluxe Sedan-currently being rehabbed
'03 Acura TL
'92 Toyota Land Cruiser
